What Is the Maximum Value of \( x \) in the Equation \( 2x+y+\frac{4}{xy}=10 \)?
  • Context: High School
  • Thread starter Thread starter anemone
The maximum value of \( x \) in the equation \( 2x+y+\frac{4}{xy}=10 \) is determined through algebraic manipulation and optimization techniques. Participants in the discussion referenced various approaches, including graphical analysis and substitution methods. The consensus indicates that the solution involves finding critical points and applying the AM-GM inequality to derive the maximum value effectively. The discussion highlights the importance of collaboration and sharing solutions for complex mathematical problems.
  • Understanding of algebraic manipulation and solving equations
  • Familiarity with optimization techniques in calculus
  • Knowledge of the AM-GM inequality
  • Ability to interpret and analyze graphical representations of equations
  • Study optimization techniques in calculus, focusing on finding maxima and minima
  • Learn about the AM-GM inequality and its applications in problem-solving
  • Explore graphical methods for analyzing equations and their solutions
  • Practice solving similar equations involving multiple variables
Mathematics students, educators, and enthusiasts interested in optimization problems and algebraic equations will benefit from this discussion.
anemone
MHB
POTW Director
Here is this week's POTW:
If the positive real numbers $x$ and $y$ satisfy the equation $2x+y+\dfrac{4}{xy}=10$, find the maximum possible value of $x$.
No one answered last POTW correctly. Participants can refer to the suggested solution below:
From the given equation, we rewrite it to get
$5-x=\dfrac{y}{2}+\dfrac{2}{xy}>0$ and this implies $x<5$.
Squaring both sides we get
$(5-x)^2=\dfrac{y^2}{4}+\dfrac{2}{a}+\dfrac{4}{x^2y^2}=\dfrac{4}{a}+\left(\dfrac{y}{2}-\dfrac{2}{xy}\right)^2\ge\dfrac{4}{x}$
And so $x(x-5)^2\ge 4$, this translates to $(x-4)(x^2-6x+1)\ge 0$, which, considering $x<5$, implies $x\le 4$.
Are we still allowed to post an answer for an old POTW?
Of course! I don't see why not, and as a matter of fact, thanks for showing interest in the old POTW!
Solve for ##y##:
We get ##y^2 + 2(x-5)y + \dfrac{4}{x}=0##
## y = 5-x \pm \sqrt{(x-5)^2- \dfrac{4}{x}}##
Now we study the discriminant ##d(x) = (x-5)^2- \dfrac{4}{x}##
We have one root ##x=4##, we then set ##d(x) = 0## and multiply both sides with ##x##:
## 0 = x^3-10x^2+25x - 4 ##
This third degree polynomial has ##x=4## as root, the other two roots we find by polymomial long-division:
## (x^3-10x^2+25x - 4)/(x-4) = x^2 - 6x+1 ##
Roots of ## x^2 - 6x+1 ## are ##3-2\sqrt{2}## and ##3+2\sqrt{2}##.
Sketch of the discriminant ##d(x) = (x-5)^2- \dfrac{4}{x}## which we did using a sign-table:
Thus in the discriminant, we must have ##3-2\sqrt{2} \leq x \leq 4## or ##x \geq 3+2\sqrt{2}##.
But since ##x \geq 3+2\sqrt{2} > 5## and ## y = 5-x \pm \sqrt{(x-5)^2- \dfrac{4}{x}}## this gives negative ##y##.
Therefore, we must have that ##3-2\sqrt{2} \leq x \leq 4##.
Answer: the largest ##x## value is 4.
Here is my solution and a plot of the equation. I got the same range for ##x## as @malawi_glenn.
Here is my plot of the original equation formatted as ##y= f(x)##, actually the sum of two solutions of the quadratic solution for ##y## and a function of ##x##.
$$ 2x + y + \frac{4}{xy} =10$$
$$ y = \left( \frac{1}{2}\left(10 - 2x\right) +\frac{1}{2} \sqrt{(10-2x)^2 -\frac{16}{x} } \large \right)$$
$$ y = \left( \frac{1}{2}\left(10 - 2x\right) -\frac{1}{2} \sqrt{(10-2x)^2 -\frac{16}{x} } \large \right)$$
The green areas are where ##y## becomes a complex number and purple areas where ##y## is negative.
You can see the range of ##y## is exactly twice the range of ##x## as can be surmised from the symmetry of the equation.
Another solution:
Multiply through by ##xy## and we have:
$$2x^2y + xy^2 + 4 - 10xy = 0$$Fix ##x## and let the left-hand side be ##f(y)##.$$f'(y) = 2x^2 + 2xy - 10x = 2x(x + y - 5)$$And ##f(y)## has a minimum at ##y = 5 - x##, where $$f_{min} = 2x^2(5-x) + x(5-x)^2 - 10x(5-x) + 4$$$$ = -x^3 + 10x^2 - 25x + 4 = -(x-4)(x^2 - 6x + 1)$$If ##f_{min} > 0##, then there is no solution for ##y## for that ##x##. We already have an obvious constraint from the original equation that ##x < 5##, so we need ##3 - 2\sqrt 2 \le x \le 4##. And we can check that ##x = 4, y = 1## is indeed a solution.
Alternatively, having noticed that ##x = 4, y = 1## is a solution and ##x < 5## we can see that ##f_{min} > 0## for ##4 < x < 5##. Hence, there are no solutions for ##x > 4##.
