B Can the same formula be used for both water and mercury manometers?
The discussion centers on the formulas used for calculating gas pressure in water and mercury manometers. For water manometers, the formula is Pgas = Patmosphere ± ρgh, while for mercury manometers, it simplifies to Pgas = Patmosphere ± h. The key question raised is why the first formula cannot be used for both types of manometers. It is explained that the numerical value of the quantity ρg varies based on the choice of units, and when using mercury, ρg equals one, leading to the simplified formula. Ultimately, both formulas yield the same results when the appropriate units are applied.
AmirWG
if we use a water manometer we get the pressure of the gas in manometer by using this forumla :
and if we use the a mercury manometer we use this formula instead :
and here's my question :
why cannot we use the first formula in both of them , realistically we can get the same results if use the first formula in case of mercury manometer
They're the same formula, because the numerical value of the quantity ##\rho{g}## depends on our choice of units. If we choose to report the pressure in units of "inches of mercury" and use mercury as the working fluid, ##\rho{g}## is equal to one and we have the second formula.
Likes AmirWG
I'm setting up an analog power supply. I have the transformer bridge and filter capacitors so far. The transformer puts out 30 volts. I am currently using two parallel power transistors and a variable resistor to set the output. It also has a meter to monitor voltage. The question is this. How do I set up a single transistor to remove whats left of the ripple after the filter capacitors. It has to vary along with the control transistors to be constant in its ripple removing. The bases of the...
  • · Replies 26 ·
  • · Replies 38 ·
10K
