Problem with conversion/ order of magnitude
  • Thread starter Thread starter KublaKhan
    Magnitude
1 reply · 6K views · last reply
KublaKhan
One cubic centimeter (1.0 cm3) of water has a mass of 1.0 multiplied by 10-3 kg.
(a) Determine the mass of 1.0 m3 of water.
(b) Assuming biological substances are 98% water, estimate the masses of a cell with a diameter of 1.0 µm, a human kidney, and a fly. Take a kidney to be roughly a sphere with a radius of 3.3 cm and a fly to be roughly a cylinder 3.3 mm long and 1.2 mm in diameter. (Type your answer using one of the following formats, 1.2e-3 for 0.0012 and 1.20e+2 for 120.)
Volume of a sphere - (4/3) * pi * radius^3
Volume of a cylinder - pi * radius^2 * height
I believe I am erroneously making the assumption that there should be 100 cubic centimeters in 1 cubic meter. As such, my proposed answer to A was 1.0E-1
It is in fact 1.0E-3
Please clear up this conversion issue for me.
On to the other problems:
I believe if I can get assistance with one, I can figure out the rest.
I have been told to assume 100% water in the calculations of these masses, so never mind the 98%.
Cell Problem: [(4/3)*pi *0.5^3 ] = .5236 *1.0E-3 kg= .005236
So I'm at 5.24E-6 kg for the weight of this cell
The correct answer should be 5.24e-16 kg/cubic centimeter. I am obviously confused over something fundamental. Any help would be much appreciated.
There are not 100 cubic centimeters in a cubic meter. There are 100 x 100 x 100 cm3 in a cubic meter. Where you're going wrong with the others are with units. You can't just stick a 0.5 in for the radius since your question is giving the diameter of the cell in micrometers.
