Problem with string arrays in assembly
The discussion revolves around converting a C++ program that displays names in message boxes into assembly language using TASM32. Participants explore issues related to string arrays, memory management, and function calls in assembly.
  • One participant shares a C++ example and their initial assembly code, noting that it displays random characters after the names.
  • Another participant suggests compiling the C++ code to assembly using a specific compiler option, indicating this could provide a clearer structure.
  • A different participant explains that the C compiler generates pointers to strings and provides an assembly snippet to illustrate how to push these pointers onto the stack.
  • Questions arise about how to access names from a defined structure and the purpose of adjusting the ESP register after function calls.
  • One participant reports success in fixing their code by saving the ECX register value during a loop iteration.
  • Another participant expresses interest in using a structure for managing string arrays and seeks clarification on how to implement this.
  • A participant provides a more complex assembly example that includes both names and a format string for output, discussing the implications of using structures versus arrays.
  • One participant shares their TASM conversion attempt but indicates they are still encountering issues, asking for further assistance.
Participants express various methods for handling string arrays in assembly, with some advocating for the use of structures while others prefer simpler arrays. There is no consensus on the best approach, and several unresolved questions remain regarding implementation details.
Discussions include assumptions about pointer sizes, stack management, and the conventions used in C versus assembly. Some participants note the complexity of managing memory and function calls in assembly compared to C.
Readers interested in assembly programming, particularly those transitioning from C or C++ and looking to understand string management and function calling conventions in assembly language.
maple23
I have been working with assembly (TASM32) for a few months now and have ran into a problem which I cannot fix. Here's a working example written in C++ which needs to be converted to assembly.
Code:
#include <windows.h>
int	main(){
	char	*name_list[5] = {"Micheal", "Stefan", "Judy", "William", "Lora"};
	for(int i = 0; i < 5; i++){
		MessageBox(0, name_list[i], name_list[i], 0);
	return 0;
Here's the assembly version I've written. It goes through the five names fine, after the names, it brings up a message box with random characters.
Code:
.386
.model flat
EXTRN	MessageBoxA : PROC
EXTRN	ExitProcess : PROC
.DATA
	dd ?			; TASM gayness
.CODE
MAIN:
	pushad
	call	lblNames
		db "Micheal", 0
		db "Stefan", 0
		db "Judy", 0
		db "William", 0
		db "Lora", 0
lblNames:
	pop	esi		; esi = current name
	push	5		; 5 names
	pop	ecx		; ecx = counter
lblNameLoop:
	push	0
	push	esi
	push	esi
	push	0
	call	MessageBoxA
lblNextChar:
	lodsb
	test	al, al
	jnz	lblNextChar
	pop	ecx
	loop	lblNameLoop
	popad
	push	0
	call	ExitProcess
END	MAIN
Does anyone know what the problem is, or have any suggestions for me? This seems much more complicated than it should be.
Sorry for my English.
Thank you,
Stefan Kendrick
Technology news on Phys.org
Why don't you just compiler the C++ code so that it produces assembly code
rather than an executable?
Usually for C this would be to use a -s or maybe -S option.
eg.
cc program.c -S
or something like that?
Using the C compiler with /Fa switch would have helped. Note that the C compiler normally generates pointers to the strings and pushes these pointers onto the stack, (or in registers if using fastcall conventions), when calling a function:
Code:
        .DATA
string1	db "Micheal", 0
string2	db "Stefan", 0
string3	db "Judy", 0
string4	db "William", 0
string5	db "Lora", 0
        .CODE
        push    offset ds:string5
        push    offset ds:string4
        push    offset ds:string3
        push    offset ds:string2
        push    offset ds:string1
        call    lblNames
        add     esp,20
However you C code isn't calling a function, instead it will look something like this:
Code:
        .DATA
name_list struct
        dd      offset ds:string1
        dd      offset ds:string2
        dd      offset ds:string3
        dd      offset ds:string4
        dd      offset ds:string5
name_list ends
After making the "name_list" STRUCT, how do I get the names from it? And why am I adding 20 to the ESP register?
I was able to fix my code with 1 more line:
Code:
lblNameLoop:
	[b]push	ecx[/b]
	push	0
	push	esi
By adding PUSH ECX, it saves the value of ECX for the next time around.
I am still interested in how to use your STRUCT function.
How do I have two string arrays being searched through at the same time? C example:
Code:
int	main(){
	char	*color_list[4] = {"red?", "orange?", "blue?", "green?"};
	char	szFullMSG[100] = "";
		for(int x = 0; x < 4; x++){
			lstrcpy(szFullMSG, "Hello, ");
			lstrcat(szFullMSG, name_list[i]);
			lstrcat(szFullMSG, ". Is your favorite color ");
			lstrcat(szFullMSG, color_list[x]);
			MessageBox(0, szFullMSG, szFullMSG, 0);
	return 0;
The "add esp,20" is used to restore the stack which was decremented by 4 (assuming 4 byte or 32 bit pointers here) for each of the 5 pushes before the call for a total of 20 bytes. This is the C convention. With the Pascal convention, the number of operands to a function is known in advance, so the function does a "ret 20" to return and restore the ESP. Using a structure is awkward, in this case, just having an array of ptrs to strings is better. Note sizeof(dword) could be used instead of the 4 on the line beginning with main0:
main0: mov esi,namep[ecx*sizeof(dword)] ;esi = ptr to a name string
Code:
        title   x
;       x.asm           Example assembly program                        ;
        .386p
        .model  FLAT
;       include C library
        IF              @Version EQ 611
        INCLUDELIB      LIBC
        ELSE
        INCLUDELIB      MSVCRTD
        INCLUDELIB      OLDNAMES
        ENDIF
;       data                                                            ;
_DATA   segment
name1   db      'Micheal',0             ;names
name2   db      'Stefan',0
name3   db      'Judy',0
name4   db      'William',0
name5   db      'Lora',0
namep   dd      offset flat:name1
        dd      offset flat:name2
        dd      offset flat:name3
        dd      offset flat:name4
        dd      offset flat:name5
nmfmt   db      '%s',00dh,00ah,000h     ;format string for printf
_DATA   ends
_BSS    segment
_BSS    ends
;       code    cs=code segment  ds=flat                                ;
_TEXT   segment use32 public 'CODE'
        extrn   _printf:NEAR            ;declare external for printf
_main   proc    near
        push    ds                      ;es=ds
        pop     es
        mov     ecx,0                   ;ecx = index to names
main0:  mov     esi,namep[ecx*4]        ;esi = ptr to a name string
        push    ecx                     ;save ecx
        push    esi                     ;display name
        push    offset flat:nmfmt
        call    _printf
        add     esp,8
        pop     ecx                     ;restore ecx
        inc     ecx                     ;loop till done
        cmp     ecx,5
        jb      main0
        xor     eax,eax                 ;exit with 0
        ret
_main   endp
_TEXT   ends
        end
Structures don't allocate memory, if you want to use a structure, you define it and then declare one or more instances of it.
Code:
NAMEPS  STRUCT
        dd      1 dup (?)
        dd      1 dup (?)
        dd      1 dup (?)
        dd      1 dup (?)
        dd      1 dup (?)
NAMEPS  ENDS
namep   NAMEPS  {\
                {offset flat:name1},\
                {offset flat:name2},\
                {offset flat:name3},\
                {offset flat:name4},\
                {offset flat:name5}}
;       requires override of namep to a ptr to dword:
main0:  mov     esi,dword ptr namep[ecx*4] ;esi = ptr to a name string
I still cannot get the code to work. Here is my TASM conversion:
Code:
.386
.model flat
extrn MessageBoxA:proc
NAMEPS	STRUCT
	dd	1 dup (?)
	dd	1 dup (?)
	dd	1 dup (?)
	dd	1 dup (?)
	dd	1 dup (?)
NAMEPS	ENDS
.DATA
	name1	db	"Micheal", 0
	name2	db	"Stefan", 0
	name3	db	"Judy", 0
	name4	db	"William", 0
	name5	db	"Lora", 0
	names	dd	offset name1
		dd	offset name2
		dd	offset name3
		dd	offset name4
		dd	offset name5
.CODE
MAIN:
	push	ds			;
	pop	es			;es = ds
	mov	ecx, 0			;ecx = counter
nameLoop:
	mov	esi, names[ecx * 4]	;ESI = pointer to name
	push	ecx			;save ecx
	push	0
	push	esi
	push	esi
	push	0
	call	MessageBoxA		;display name
	add	esp, 8
	inc	ecx			;
	cmp	ecx, 5			;loop till done
	jb	nameLoop
	xor	eax, eax		;eax = 0
	ret
END	MAIN
Do you know what is wrong?
Thanks you for your help.
Code:
"offset" should be "offset flat:" or possibly "offset ds:"
Code:
	push	0
	push	esi
	push	esi
	push	0
	add	esp, 8
Just looked at this again, the "add esp,8" needs to be "add exp,16" to compensate for the 4 pushes done (16 bytes).
I still get the same error. The program gives a message box with the first name and then closes unexpectedly.
My fault, WINAPI functions use pascal calling conventions. Remove the "add esp,16" after the call to "MessageBoxA". Note that non-windows C functions, like malloc() and printf() use "C" calling conventions which require the caller to restore ESP. On my system, using Visual Studio 2005, I have to use __imp__MessageBoxA@16, which is a MessageBox function with argument size of 16 bytes, so it does a "ret 16" when returning, so the call doesn't have to do a "add esp,16" afterwards:
Code:
        push    ecx                     ;save ecx
        push    0                       ;display message box
        push    esi
        push    esi
        push    0
        call    __imp__MessageBoxA@16
Thank you! :smile: The code works perfectly!
Code:
.386
.model flat
.DATA
	name3	db	"Judy", 0
	name5	db	"Lora", 0
	names	dd	offset ds:name1
		dd	offset ds:name2
		dd	offset ds:name3
		dd	offset ds:name4
		dd	offset ds:name5
.CODE
MAIN:
	push	ds			;
	pop	es			;es = ds
	mov	ecx, 0
nameLoop:
	push	ecx			;save ecx
	push	0
	push	esi
	push	esi
	push	0
	inc	ecx			;
	jb	nameLoop
	ret
END	MAIN
