Problems on Length contraction
9 replies · 9K views · last reply
chingcx
Problems on "Length contraction"
This is a problem in my text. The idea is that a bar is moving with a high speed (say 0.5c) relative to us. We now want to know what will be the length appeared to us if the bar is parallel, perpendicular and 60 degrees tilted. And we are asked when the bar is tilted, how long is it in the co-moving frame.
L=(Lo)/y where Lo is the proper length
First two are very straight-forward, but I can't understand the difference between the last two questions. I tried to resolve the velocity component but still I could not work it out.
Any explanation is appreciated, thank you in advance.
Ok. So you know in this problem that the observer of the bar is going to see the bar a shorter length in the, let's say +x direction. The only parts of the bar that will shrink are the parts parallel to its' velocity; its not going to shrink vertically or diagonally. You will have to modify your Lorentz factor to account for the velocity in the x direction only.
Two coordinate frame diagrams side by side. Left, labelled Fixed frame, has axes z, y and x. Right, labelled Moving frame, has axes z', y' and x'. A red bar on the x' axis is marked x'1 and x'2 with L0 beneath it, and a grey arrow labelled v points right along x'.
The length of any object in a moving frame will appear foreshortened in the direction of motion, or contracted. The amount of contraction can be calculated from the Lorentz transformation. The length is maximum in the frame in which the object is at rest.
Text and equations deriving length contraction: L0 = x2' - x1' equals (x2 - vt2 - x1 + vt1) over the square root of (1 - v^2/c^2); with t2 = t1, L = L0 times the square root of (1 - v^2/c^2) equals L0/gamma.
  • Two side-by-side coordinate diagrams: left, Fixed frame with z, y and x axes; right, Moving frame with z', y' and x' axes, a red rod from x'1 to x'2 labelled L0 on the x' axis, and a grey arrow labelled v pointing along +x'.
  • Two coordinate frames side by side: a fixed frame with axes z, y and x, and a moving frame with axes z', y' and x'. In the moving frame a red rod runs along x' from x'1 to x'2, labelled L0, and a grey arrow labelled v points in the +x' direction.
  • Text derivation of length contraction: L0 = x'2 - x'1 equals (x2 - vt2 - x1 + vt1) over the square root of (1 - v^2/c^2), then with t2 = t1 gives L = L0 times the square root of (1 - v^2/c^2), which equals L0/gamma.
Ok and thank you, but did you misunderstand my question? The bar is still moving in +x direction, but the orientation of the bar is not along +x direction, but make an angle of 60 degrees instead. So I think the velocity of the bar is still 0.5c in +x direction, and this is the thing I don't really understand...
physixguru said:
Two coordinate diagrams side by side: left, 'Fixed frame' with z, y and x axes; right, 'Moving frame' with z', y' and x' axes, a red bar lying along x' between marks x'1 and x'2 labelled L0, and a grey arrow labelled v pointing in the +x' direction.
Derivation of length contraction: L0 = x2' - x1' equals (x2 - vt2 - x1 + vt1) over the square root of (1 - v^2/c^2); with t2 = t1 gives L = L0 times the square root of (1 - v^2/c^2), equal to L0/gamma, labelled Length contraction.
Oh, I know this already, and this problem is somehow different in my opinion, thank you anyway.
At a just got up guess, you have to resolve the velecity for the x direction (as it is now moving in two planes relative to the stationary reference frame. Also you need to resolve the apparent length in the x direction using simple trig?
Hint: Only the component of length parallel to the direction of motion will be contracted. Find the x & y dimensions in the proper ("moving") frame, then transform to the "stationary" frame.
Thank you. In fact, the textbook problem set v=0.8c (relative to a frame S) and L=1m, and the answers are 0.917m (as observed in the stick's rest frame) and 0.832m (as observed in S) respectively.
From your hint, I get 0.917m, which I expected to be the length observed in S and I've no idea how 0.832m is arrived at. So what's the difference we will see in stick's rest frame and in S frame?
The length of the stick in its rest frame is 1 m, of course. (That's what L = 1m means, I presume.) The length of the stick in frame S is about 0.917 m. I have no idea what 0.832 m is supposed to be.
Is the bar still at a 60 degree angle as seen in the unmoving frame?
No. Since only the horizontal dimension 'contracts', the angle of the bar must change.
