Product of two boosts and then two inverse boosts is rotation matrix
  • Thread starter Thread starter Kick-Stand
The discussion revolves around the composition of Lorentz boosts and their relationship to rotation matrices. The original poster is exploring whether there is a more elegant method to demonstrate that the product of two boosts and their inverses results in a rotation matrix, particularly under the assumption of small velocities.
  • The original poster considers using Taylor expansions for the boost matrices and questions whether this approach leads to an overly complicated result. They also express uncertainty about their setup and whether they are missing a simpler method.
Participants are actively engaging with the original poster's concerns, providing observations about the assumptions made regarding the boosts. Some suggest re-evaluating the coordinate system for the second boost to simplify the problem further. There is a mention of Wigner rotation, indicating a potential direction for understanding the transformation resulting from the composition of boosts.
The original poster notes that the boosts are orthogonal and that they are working under the condition that the velocities are small. There are also references to issues with LaTeX formatting in the forum, which may affect the clarity of the discussion.
Kick-Stand
Let ##\Lambda(\mathbf{v})## be a Lorentz boost associated with the three velocity ##\mathbf{v}## and set ##R = \Lambda(\mathbf{v})\Lambda(\mathbf{w})\Lambda(-\mathbf{v})\Lambda(-\mathbf{w})## where ##\mathbf{v}\cdot\mathbf{w} = 0## and ##v,w\ll 1##. Then ##R## is a rotation matrix.
For ##\mathbf{v} = v_1 \mathbf{e}_1 + v_2\mathbf{e}_2 + v_3\mathbf{e}_3## and ##\gamma = (1-v^2)^{-1/2}##, where we use natural units with ##c=1##, the boost associated to ##\mathbf{v}## is given by
\Lambda(\mathbf{v}) & = \begin{pmatrix}
\gamma & -\gamma v_1 & -\gamma v_2 & -\gamma v_3 \\
-\gamma v_1 & 1 + (\gamma-1)\frac{v_1^2}{v^2} & (\gamma-1)\frac{v_1 v_2}{v^2} & (\gamma-1)\frac{v_1 v_3}{v^2} \\
-\gamma v_2 & (\gamma-1)\frac{v_1 v_2}{v^2} &1 + (\gamma-1)\frac{v_2^2}{v^2} & (\gamma-1)\frac{v_2 v_3}{v^2} \\
-\gamma v_3 & (\gamma-1)\frac{v_1 v_3}{v^2} & (\gamma-1)\frac{v_2 v_3}{v^2} &1 + (\gamma-1)\frac{v_3^2}{v^2} \\
\end{pmatrix}
while for ##v\ll 1## we have ##\gamma = 1 + \frac{1}{2} v^2 + O(v^4)## and ##v\gamma = v + O(v^3)##.
So is there some elegant way to do this or am I just supposed to follow my nose and sub the Taylor expansions for terms in the two boost matrices under the assumption ##v,w\ll 1##, then do three ugly matrix multiplications and get some horrifying kludge for ##R## and show that the product of ##R## and its transpose is the identity matrix with det(R)=1?
Without loss of generality I made ##\mathbf{v}## point along the x-axis and since ##\mathbf{v}\cdot\mathbf{w} = 0## I set ##w_1 = 0## to make the boosts a little easier to deal with. But it still comes out a pretty ugly kludge even with ##\Lambda(\mathbf{v})## a very simple boost matrix. Is this the way I need to do the problem or am I missing something that makes this easy instead of brute forcing like a dummy?
Ugh what am I doing wrong in the homework statement and relevant equations? Double pound for inline latex and double dollar signs for displayed latex right?
Nothing. LaTeX at PF has been dodgy since the last XenForo upgrade and it just doesn't work in some places. Probably the best thing to do is quote your entire OP and remove the quote tags, like this.
OP's question was:
Homework Statement: Let ##\Lambda(\mathbf{v})## be a Lorentz boost associated with the three velocity ##\mathbf{v}## and set ##R = \Lambda(\mathbf{v})\Lambda(\mathbf{w})\Lambda(-\mathbf{v})\Lambda(-\mathbf{w})## where ##\mathbf{v}\cdot\mathbf{w} = 0## and ##v,w\ll 1##. Then ##R## is a rotation matrix.
Relevant Equations: For ##\mathbf{v} = v_1 \mathbf{e}_1 + v_2\mathbf{e}_2 + v_3\mathbf{e}_3## and ##\gamma = (1-v^2)^{-1/2}##, where we use natural units with ##c=1##, the boost associated to ##\mathbf{v}## is given by
\Lambda(\mathbf{v}) = \begin{pmatrix}
\end{pmatrix}
Immediate observation: you correctly identified that you can set ##\mathbf{v}## to point along x, but you only set ##w_1## to zero?
Is that not the most general condition on ##\mathbf{w}## for
vw_1 = \mathbf{v}\cdot\mathbf{w}=0
to hold? Of course assuming ##v\neq 0##.
Sure. But you already set the coordinate system in a clever way to simplify the representation of v - why not make the same move for w?
Then have a think about what type of transformation the composition of two boosts must be.
Ugh I'll have to do it tomorrow, I have to be up for work in 4 1/2 hours lol. Thanks.
Duh, since ##\mathbf{v},\mathbf{w}## are orthogonal I can just choose the y axis to correspond to either ##\mathbf{w}## or ##-\mathbf{w}##, whichever way ensures a right handed coordinate system.
So only after Taylor expanding ##\gamma_v, v\gamma_v, \gamma_w, w\gamma_w## for ##v,w\ll 1## and only keeping terms up to second order (e.g. ##1, v, w, v^2, w^2, vw##) do I get a rotation matrix, e.g. ##R^T R = I## and det(R) = 1 to second order, with my rotation matrix given by
R = \begin{pmatrix}
1 & 0 & 0 & 0 \\
0 & 1 & \pm vw & 0 \\
0 & \mp vw & 1 & 0 \\
0 & 0 & 0 & 1
\end{pmatrix}
where the sign in the ##\pm## and ##\mp## is based on whether ##\mathbf{w}## points in the same direction as ##\mathbf{e}_2## or in the opposite direction. Kind of anti-climactic to get such a simple rotation matrix to second order lol.
You might want to have a quick look at Wigner rotation, which says that the composition of two boosts can be rewritten as a single boost and a rotation. So I think you can see what's happening here by compositing the two "plus" boosts and, separately, the two "minus" boosts. Then when you composite those two transforms they almost cancel for low velocities (they would cancel exactly in the Galilean case), and the residual transform is dominated by their rotations.
Any book to recommend with a good derivation of the result? Wikipedia is awful IMO.
You could always figure it out for yourself. The Wigner rotation is essentially caused by a convention that underlies the Lorentz Transformation:
