- 8,130
- 574
- TL;DR
- product with undefined term
Let c=ab. Let b be undefined (but finite). If a=0, is c undefined or does c=0?
The discussion centers on the mathematical expression c=ab, where b is defined as finite but undefined, and a is equal to 0. Participants conclude that c must equal 0 based on the property that 0 multiplied by any real number yields 0. However, they debate the implications of having an undefined term and the necessity of the distributive law for valid proofs. The conversation also touches on limits and the behavior of functions as they approach zero, particularly in relation to the expression xsin(1/x).
PREREQUISITESMathematicians, students of calculus, computer scientists dealing with numerical methods, and anyone interested in the implications of undefined terms in mathematical expressions.
It is 0, afaik. Using limits, let ##\epsilon \rightarrow 0## assume a is not really zero but very small and you can make the product very small thanks to the bound on c: ## ab < Max(b) \frac {\epsilon}{ Max(b)} ## for all ##\epsilon##.mathman said:Summary: product with undefined term
Not necessarily. Even if we assume ##0## as neutral element of addition, and the unwritten operation as a multiplication, it is not clear if we have the distributive law, or another combination of the two operations. Furthermore, we need an additive inverse and an element ##a\neq 0##. If we lack any of these, then I don't know a valid proof for ##0\cdot b=0##.WWGD said:It is 0, afaik.
Math_QED said:What does ##b## finite but undefined even mean??
See my previous. This is used e.g. to conclude that lim h-->0 hSin(1/h)=0 . The expression is bounded above by ##Max(a)\frac{\epsilon}{Max(a)}## for all ##\epsilon##.fresh_42 said:Not necessarily. Even if we assume ##0## as neutral element of addition, and the unwritten operation as a multiplication, it is not clear if we have the distributive law, or another combination of the two operations. Furthermore, we need an additive inverse and an element ##a\neq 0##. If we lack any of these, then I don't know a valid proof for ##0\cdot b=0##.
Yes, but you already make a hidden assumption, namely that we are talking about ordinary numbers.WWGD said:See my previous. This is used e.g. to conclude that lim h-->0 hSin(1/h)=0 . The expression is bounded above by ##Max(a)\frac{\epsilon}{Max(a)}## for all ##\epsilon##.
How are they not ordinary numbers? Arent they all assumed to be Real numbers? Whatever value the bounded undefined takes, the product will be bounded above by epsilon.fresh_42 said:Yes, but you already make a hidden assumption, namely that we are talking about ordinary numbers.
Who knows? I always think in terms of algebras, in which multiplication is not a natural given extension of school counting. But I admit that distribution is one of the very basic and here crucial properties, which is usually assumed.WWGD said:How are they not ordinary numbers? Arent they all assumed to be Real numbers?
Fair enough, I was assuming numbers were Real. If not, it is a whole different situation. When we talk about bounded I guess we assume a modulus or valuation.fresh_42 said:Who knows? I always think in terms of algebras, in which multiplication is not a natural given extension of school counting.
I have found another proof, which only uses the distributive law, and characteristic not two. Again, everything depends on the distributive law. Given that we can conclude with ##a-a=0##, either for an ##a\neq 0## or for ##a=0## with ##\operatorname{char} \neq 2##.WWGD said:But in what setting outside of the Reals does a question like this make sense? Maybe @mathman can clarify the setting?
Instead of making assumptions about what is being asked here, why don't we hold off until @mathman returns to clarify what sorts of things a, b, and c are?mathman said:Let c=ab. Let b be undefined (but finite). If a=0, is c undefined or does c=0?
Then just let x approach 0 as ##\epsilon/(Max(Sin(1/x))= \epsilon/1 ## so that ## xsin(1/x) < \epsilon \cdot 1 = \epsilon ## for all ## \epsilon##mathman said:Clarification: I was thinking about expressions like xsin(1/x) for x=0. Real numbers and ordinary multiplication.
Then the operation of multiplication is undefined. Axioms/rules only stipulate multiplication within the Real numbers.WWGD said:Then just let x approach 0 as ##\epsilon/(Max(Sin(1/x))= \epsilon/1 ## so that ## xsin(1/x) < \epsilon \cdot 1 = \epsilon ## for all ## \epsilon##
mathman said:An interest variation is about ##f(x)=x^2sin(1/x)##, with ##f'(x)=2xsin(1/x)-cos(1/x)## for ##x\ne 0##, which is undefined as ##x\to 0##, but ##f'(0)=0##
Yes, since 1/0 is undefined, then so is sin(1/0), so the product 0 * sin(1/0) is undefined.mathman said:However there seems to be a school of thought which asserts that sin(1/0) being undefined, multiplying by 0 results in an undefined product.
You can't even say that b (= sin(1/0) here) is finite.mathman said:Let c=ab. Let b be undefined (but finite). If a=0, is c undefined or does c=0?
But computer floating point math isn't relevant here because of the inherent limitations of representing very small or very large numbers in a finite number of bits, particularly floating point numbers as described by IEEE-754, which describes different situations in which NANs (both signalling and nonsignalling) are produced. I'm aware that there are libraries that support larger numbers and higher precision than the 2-, 4-, 8, or 10-byte floating point numbers described in IEEE-754, but I'm not familiar with the limitations of those libraries. In any case, if these libraries store numbers have less than infinite precision, and signal events such as underflow and the like, then they too have limitations.jedishrfu said:Computer math follows that trend when some factor isn't computable then a NaN is returned and this taints the rest of the calculation resulting in a NaN as the final answer.
