Product with an undefined term
24 replies · 3K views
Discussion
Mathematics news on Phys.org
Mentor
- 15,796
- 10,682
Since B is finite and we assume B is element of the Reals and A is 0 then C must be 0.
"0 times any real number = 0" is a property of 0.
member 587159
What does ##b## finite but undefined even mean??
- 20,819
- 28,467
Or what does c=ab mean? For the conclusion 0b=0 we need the distributive law and a loop for a.
Homework Helper
- 7,887
- 13,197
It is 0, afaik. Using limits, let ##\epsilon \rightarrow 0## assume a is not really zero but very small and you can make the product very small thanks to the bound on c: ## ab < Max(b) \frac {\epsilon}{ Max(b)} ## for all ##\epsilon##.mathman said:Summary: product with undefined term
Let c=ab. Let b be undefined (but finite). If a=0, is c undefined or does c=0?
- 20,819
- 28,467
Not necessarily. Even if we assume ##0## as neutral element of addition, and the unwritten operation as a multiplication, it is not clear if we have the distributive law, or another combination of the two operations. Furthermore, we need an additive inverse and an element ##a\neq 0##. If we lack any of these, then I don't know a valid proof for ##0\cdot b=0##.WWGD said:It is 0, afaik.
Homework Helper
Education Advisor
- 7,864
- 1,605
Math_QED said:What does ##b## finite but undefined even mean??
Perhaps it means that the vlerth level of b is less than 16, but we don't know what a vlerth level is.
Homework Helper
- 7,887
- 13,197
See my previous. This is used e.g. to conclude that lim h-->0 hSin(1/h)=0 . The expression is bounded above by ##Max(a)\frac{\epsilon}{Max(a)}## for all ##\epsilon##.fresh_42 said:Not necessarily. Even if we assume ##0## as neutral element of addition, and the unwritten operation as a multiplication, it is not clear if we have the distributive law, or another combination of the two operations. Furthermore, we need an additive inverse and an element ##a\neq 0##. If we lack any of these, then I don't know a valid proof for ##0\cdot b=0##.
- 20,819
- 28,467
Yes, but you already make a hidden assumption, namely that we are talking about ordinary numbers.WWGD said:See my previous. This is used e.g. to conclude that lim h-->0 hSin(1/h)=0 . The expression is bounded above by ##Max(a)\frac{\epsilon}{Max(a)}## for all ##\epsilon##.
Homework Helper
- 7,887
- 13,197
How are they not ordinary numbers? Arent they all assumed to be Real numbers? Whatever value the bounded undefined takes, the product will be bounded above by epsilon.fresh_42 said:Yes, but you already make a hidden assumption, namely that we are talking about ordinary numbers.
- 20,819
- 28,467
Who knows? I always think in terms of algebras, in which multiplication is not a natural given extension of school counting. But I admit that distribution is one of the very basic and here crucial properties, which is usually assumed.WWGD said:How are they not ordinary numbers? Arent they all assumed to be Real numbers?
Homework Helper
- 7,887
- 13,197
Fair enough, I was assuming numbers were Real. If not, it is a whole different situation. When we talk about bounded I guess we assume a modulus or valuation.fresh_42 said:Who knows? I always think in terms of algebras, in which multiplication is not a natural given extension of school counting.
- 20,819
- 28,467
I have found another proof, which only uses the distributive law, and characteristic not two. Again, everything depends on the distributive law. Given that we can conclude with ##a-a=0##, either for an ##a\neq 0## or for ##a=0## with ##\operatorname{char} \neq 2##.WWGD said:But in what setting outside of the Reals does a question like this make sense? Maybe @mathman can clarify the setting?
However, if distribution is not given, then everything is possible.
Mentor
- 38,146
- 10,750
Instead of making assumptions about what is being asked here, why don't we hold off until @mathman returns to clarify what sorts of things a, b, and c are?mathman said:Let c=ab. Let b be undefined (but finite). If a=0, is c undefined or does c=0?
Clearly if a, b, and c are members of the real or complex field, the question is trivial and undeserving of an 'A' tag.
Homework Helper
- 7,887
- 13,197
Then just let x approach 0 as ##\epsilon/(Max(Sin(1/x))= \epsilon/1 ## so that ## xsin(1/x) < \epsilon \cdot 1 = \epsilon ## for all ## \epsilon##mathman said:Clarification: I was thinking about expressions like xsin(1/x) for x=0. Real numbers and ordinary multiplication.
Homework Helper
- 8,130
- 575
I am well aware that the limitng process gives 0. However there seems to be a school of thought which asserts that sin(1/0) being undefined, multiplying by 0 results in an undefined product.
An interest variation is about ##f(x)=x^2sin(1/x)##, with ##f'(x)=2xsin(1/x)-cos(1/x)## for ##x\ne 0##, which is undefined as ##x\to 0##, but ##f'(0)=0##
Mentor
- 15,796
- 10,682
Computer math follows that trend when some factor isn't computable then a NaN is returned and this taints the rest of the calculation resulting in a NaN as the final answer.
Homework Helper
- 7,887
- 13,197
Then the operation of multiplication is undefined. Axioms/rules only stipulate multiplication within the Real numbers.WWGD said:Then just let x approach 0 as ##\epsilon/(Max(Sin(1/x))= \epsilon/1 ## so that ## xsin(1/x) < \epsilon \cdot 1 = \epsilon ## for all ## \epsilon##
Homework Helper
Education Advisor
- 7,864
- 1,605
mathman said:An interest variation is about ##f(x)=x^2sin(1/x)##, with ##f'(x)=2xsin(1/x)-cos(1/x)## for ##x\ne 0##, which is undefined as ##x\to 0##, but ##f'(0)=0##
f'(x) is defined as ##\lim_{h \rightarrow 0} \frac{f(x+h) - f(x)}{h}##, so ##f'(x)## doesn't exist at a value ##x## where ##f(x)## doesn't exist. So I assume you are defining ##f(0)## to be ##\lim_{x \rightarrow 0}x^2 sin(1/x) = 0##.
I don't understand how this example illustrates the question in your original post.
Mentor
- 38,146
- 10,750
Yes, since 1/0 is undefined, then so is sin(1/0), so the product 0 * sin(1/0) is undefined.mathman said:However there seems to be a school of thought which asserts that sin(1/0) being undefined, multiplying by 0 results in an undefined product.
You can't even say that b (= sin(1/0) here) is finite.mathman said:Let c=ab. Let b be undefined (but finite). If a=0, is c undefined or does c=0?
However, you can work with limits to establish that ##\lim_{x \to 0} x \cdot \sin(\frac 1 x)## exists and is 0, which is easy to show without resorting to the limit definition. I.e., ##\forall x \gt 0, -x \le x \cdot \sin(\frac 1 x) \le x ##. Since both bounds approach 0 as x approaches 0, so must the expression in the middle.
Mentor
- 38,146
- 10,750
But computer floating point math isn't relevant here because of the inherent limitations of representing very small or very large numbers in a finite number of bits, particularly floating point numbers as described by IEEE-754, which describes different situations in which NANs (both signalling and nonsignalling) are produced. I'm aware that there are libraries that support larger numbers and higher precision than the 2-, 4-, 8, or 10-byte floating point numbers described in IEEE-754, but I'm not familiar with the limitations of those libraries. In any case, if these libraries store numbers have less than infinite precision, and signal events such as underflow and the like, then they too have limitations.jedishrfu said:Computer math follows that trend when some factor isn't computable then a NaN is returned and this taints the rest of the calculation resulting in a NaN as the final answer.
Mentor
- 15,796
- 10,682
At the time, I felt the computer math rule of returning a NaN was useful in explaining how an inner expression that’s undefined can taint the final result making it undefined not that computer math was needed to answer the question.
My apologies for sidetracking the thread.
Undergrad Definite integral is undefined and not undefined
- dyn
- · Replies 8 ·
- Calculus
- Replies
- 8
Prove Product of Polynomials: No Odd Degree Terms
- anemone
- · Replies 1 ·
- General Math
- Replies
- 1
Why does a division by zero produce an error or undefined message?
- AtoMick-u235
- · Replies 32 ·
- Programming and Computer Science
- Replies
- 32
High School Why Isn't x/0 = x, Instead of Undefined?
- bballwaterboy
- · Replies 6 ·
- General Math
- Replies
- 6
Undergrad Is 0 to the Power of 0 Undefined or Equal to 1?
- aeiti
- · Replies 3 ·
- General Math
- Replies
- 3
Undergrad How is this product of terms calculated?
- crv357
- · Replies 2 ·
- General Math
- Replies
- 2
Can a function with undefined derivative at a point still be continuous there?
- bearn
- · Replies 9 ·
- Calculus
- Replies
- 9
Finding k for x is undefined at $x=2$
- karush
- · Replies 3 ·
- Calculus
- Replies
- 3
Undergrad Product of cosines with equal angle increments as sum of cosines
- swampwiz
- · Replies 1 ·
- General Math
- Replies
- 1
Undergrad Are undefined constants valid in trig equations when other constants present?
- Sduibek
- · Replies 3 ·
- General Math
- Replies
- 3
