Programming in C++: 3D array string copy
3 replies · 4K views
Dembadon
I am making a Klondike style solitaire game, and I am trying to load a string into a 3D array. I am representing the "Tableau" with a 3D array (we haven't gone over structs yet). I want to represent the spaces which don't have cards with the word "empty". I'm not understanding how to copy a C-style string to a 3D array.
My compiler, g++, is giving me the following error:
Code:
uploadTest.cpp: In function ‘void strCopy(char (*)[60][80], char*)’:
uploadTest.cpp:240: error: incompatible types in assignment of ‘char’ to ‘char [80]’
Here are my array declarations:
Code:
char emptyRow[ MAX_STR_LEN ] = "empty";
char tableau[ MAX_ROWS ][ MAX_COLS ][ MAX_STR_LEN ];
Here's how it is called:
Code:
strCopy( tableau, emptyRow );
Code:
// prototype
void strCopy( char destArr[ MAX_ROWS ][ MAX_COLS ][ MAX_STR_LEN ],
						char srcArr[ MAX_STR_LEN ] );
// implementation
						char srcArr[ MAX_STR_LEN ] ) {
	// initialize function/variables
	int colI = 0;
	int rowIndex = 0, colIndex = 0;
	// loop through source array
	while( srcArr[ colI ] != NULL_CHAR ) {
		// assign character
		destArr[ rowIndex ][ colIndex ] = srcArr[ colI ];
		// increment index
		colI++;
Do I have to create a third index for the destArr and increment it? I tried doing this but the compiler still complained.
Code:
Code:
Code:
Code:
// prototype
// implementation
	int colI = 0;
		// assign character
		// increment index
		colI++;
Instead of copying characters one by one, which appears to be what you think you're doing, why not use the strcpy C standard library function?
Here's where your error is coming from, I believe.
Code:
The problem is a mismatch of types. On the left side, destArr[ rowIndex ][ colIndex ] is an address, the address of the first character in the string it will hold. On the right side is a character. This is what your compiler error message is saying.
Also, since your tableau array is essentially a two-dimensional array of strings, I would use an outer for loop to iterate through the rows, and an inner for loop to iterate through the columns in a particular row. Presumably you know how many rows and columns there will be.
Here's how I would do what you're trying to do. Notice that I added a couple of parameters for the number of rows and columns of the tableau. This should work, but I haven't had time to test it.
Code:
void strCopy( char destArr[ ][ ], srcArr[ ], int rows, int cols )
   int i, j;
   for (i = 0; i < rows, ++i)
      for (j = 0; j < cols; ++j)
         strcpy(destArr[i][j], srcArr);
Thank you for your help, Mark! I now understand my error with array assignments, and the strCopy function you provided worked.
Additionally, we went over structs today in class, and I think I can already find a good use for them in this program. I'm planning on making a "card" struct, which will hold three elements: rank, suit, color. I can then declare a deck array of size 52, load it from a file, and use then use it to populate my tableau. I also don't think I'll need a 3D array for the tableau anymore, since I should just be able to load the tableau at a given row and column using my newly created deck array.
Sure, you're welcome, and glad to hear that it worked for you.
Sounds good!
