Programming with C (math library error)
  • Thread starter Thread starter SnakeDoc
    Error Programming
6 replies · 2K views
SnakeDoc
I have make a program that solves the distance between 2 points on a triangle.
none
Code:
/* homework 1 */
#include <stdio.h>
#include <math.h>
int main(void)
// Declare and initialize variables
  float x1=1, y1=5, x2=4, y2=7;
  float dx, dy, distance;
// Compute sides of a right triangle
  dx = x2 - x1;
  dy = y2 - y1;
  distance = sqrt (dx*dx + dy*dy);
// Print distance
  printf("The distance between the two points is: %5.2f \n",distance);
// Exit program
return(0);
I keep getting a an error about an undefined reference to sqrt
Did I do something wrong?
none
/* homework 1 */
#include <stdio.h>
#include <math.h>
int main(void)
dx = x2 - x1;
dy = y2 - y1;
// Print distance
// Exit program
return(0);
Your program runs fine for me, although I get this warning:
warning C4244: '=' : conversion from 'double' to 'float', possible loss of data
due to the fact that sqrt() returns a double, and you're storing the returned value in a smaller type. I suspect you don't have things set up correctly so that the compiler can't find the header files (math.h in particular).
I use Pascal rather than C++ but in Pascal, if you reference a "math" library in order to use the "sqrt" function, you would have to use "math.sqrt(dx*dx+ dy*dy)".
This is C, not C++, and you simply use sqrt, without a math. attached to it. You also need to #include the math header,
C:
#include <math.h>
For historical reasons, the math functions are not part of the standard library, so the math library must be specifically linked to. For instance
Code:
gcc -O mymathcode.c -lm
C:
#include <math.h>
Code:
I'm guessing that the OP doesn't have his compiler installation set up correctly, with the linker unable to find the code for the math library (DrClaude's earlier suggestion). Less likely, I think, is my earlier suggestion that the compiler can't find the headers, but this is still a possibility.
