Projectile motion, 30 and 60 degrees on a level plain
2 replies · 8K views · last reply
nooobie
prove that two bullets fired at 30 and 60 degrees will travel the same distance, and the 60 degree shot will travel 3 times as high as the 30 degree.
S(displacement) Vo(initial velocity) Vf(final Velovity) t(time) a(acceleration due to gravity)
S=volt + .5at^2
S=Vft - .5at^2
S= (Vft - volt)/2
Vf^2= Vo^2 + 2aS
Vf= Vo +at
ive tried numerous ways, but i can't seem to get past point of the final velocity at the peak being zero to solve for time in the last equation...and i can't figure out what to do from there
The motion is in two directions; the x- and y-directions. At the peak the speed in the y-direction is zero, but there is still speed in the x-direction. You need to analyse this problem in two-dimensions.
Hi
To prove that the 60° shot will travel 3 times as high as the 30°:
You can use the conservation of energy: Kinetic Engergy at the time of the shot equals the potential energy at the peak.
[tex]E_{kin}=E_{pot}[/tex]
For [tex]E_{kin}[/tex] you have to take the angle into account:
[tex]E_{kin}=\frac{1}{2}*m*v_{0}^{2}*sin(\alpha)^{2}[/tex]
Solve for h (=max height) and compare the values for 30 and 60 degrees.
I hope this helps...
