Projectile Motion (not on Earth)
11 replies · 2K views · last reply
randomphysicsguy123
A truck is dropped out of a building that is 20 meters high. When the truck started to fall, it went 1 meter after the first second. After a total of 3 seconds, how high is the truck located from the ground? (Hint: This is not on earth)
delta y = vt+1/2at^2
I know I need to solve for acceleration as I am not on Earth and I am assuming I should create a distance vs. time graph. But overall I am unsure what to do. Please help been stuck on this for a while.
randomphysicsguy123 said:
Homework Statement:: A truck is dropped out of a building that is 20 meters high. When the truck started to fall, it went 1 meter after the first second. After a total of 3 seconds, how high is the truck located from the ground? (Hint: This is not on earth)
Relevant Equations:: delta y = vt+1/2at^2
One metre in one second is an average speed of ##1m/s##, right?
Correct. But could you provide a bit more insight as what I should do I am really lost.
How is average speed related to acceleration?
average speed=d/t
a=change in v/ change in time
average speed=d/t
Can you use those to find the acceleration on the mystery planet?
Yes I could however I keep getting 1m/s^2 but when xf=xi+vit+1/2a*t2 to check if that statement is true I get .92m/s^2
If the acceleration is ##1m/s^2##, how far does the object fall in the first second?
1 meter
If that was a guess it was wrong. Why not use ##s = ut + \frac 1 2 a t^2##, with ##u = 0## and ##t = 1s##?
Why guess when you have SUVAT equations?
Didn't think about that. Regardless, I already turned it in and I used the equation xf=xi+vit+1/2a*t^2, which got me 15.86 meters at 3 seconds. Hope it was right. Thank you for your help.
xf=xi+vit+1/2a*t^2 tells you that, starting from rest, the distance is proportional to t2. So after three times the time, how many times the distance?
