Projectile motion with friction in MATLAB (ODE45)
4 replies · 7K views · last reply
cwrn
I'm working on a little project where I want to plot the motion of a projectile with air resistance. The air resistance can be assumed to be proportional to the velocity squared.
[itex]F_{f}=-Bv^{2}[/itex]
[itex]F_{f,x}=F_{f}\frac{v_{x}}{v}, \ \ F_{f,y}=F_{f}\frac{v_{y}}{v}[/itex]
where B depends on the height, y above the ground
[itex]B(y) = B_{0}e^{-y/y_{0}}[/itex]
Given
[itex]k = \frac{B_{0}}{m}=4\cdot 10^{-5} \ m^{-1}, \ y_{0} = 1\cdot 10^4 \ m, \ v_{0} = 700 \ m/s[/itex]
I have derived the equations of motion as following:
[itex]\vec{r}=\left(v_{0}tcos\theta-\frac{1}{2}kvv_{x}e^{-y/y_{0}}\cdot t^2\right)\hat{i}+\left(v_{0}tcos\theta+\frac{1}{2}\left[\vec{g}-kvv_{y}e^{-y/y_{0}}\right] t^2\right)\hat{j}[/itex]
[itex]\vec{v}=\left(v_{0}cos\theta-kvv_{x}e^{-y/y_{0}}\cdot t\right)\hat{i}+\left(v_{0}sin\theta+\left [\vec{g}-kvv_{y}e^{-y/y_{0}}\right]t\right)\hat{j}[/itex]
[itex]\vec{a}=\left(-kvv_{x}e^{-y/y_{0}}\right)\hat{i}+\left(\vec{g}-kvv_{y}e^{-y/y_{0}}\right)\hat{j}[/itex]
I'm having trouble defining a function I can use with ode45 since there are several variables depending on each other (assuming my equations are correct). Any tips would be greatly appreciated.
I haven't checked if the equations are correct, but they are not differential equations!
What you need for ode45 is something like
\begin{align}
\frac{dx}{dt} &= v_x \\
\frac{dy}{dt} &= v_y \\
\frac{dv_x}{dt} &= a_x \\
\frac{dv_y}{dt} &= a_y
\end{align}
where you replace ##a_x## and ##a_y## by the proper expressions involving the forces.
\begin{align}
\end{align}
Yes, I'm aware of this. Solving this with ode45 should yield the x and y vectors that I want to plot. I'm just not sure how to define the function itself since it depends on B which in turn depends on y.
\begin{align}
\end{align}
If you take the array y to contain ##(x,y,v_x,v_y)##, then you would write something like
Code:
function dy = projectile(t,y)
B0 = 1;
y0 = 123;
dy = zeros(4,1);    % a column vector
dy(1) = y(3);
dy(2) = y(4);
dy(3) = B0 * exp(-y(2)/y0) * y(3);
dy(4) = B0 * exp(-y(2)/y0) * y(4);
(Note that the code doesn't correspond to your problem.)
\begin{align}
\end{align}
You start off your calculations with a known position for the projectile, which means you are going to know an initial value for y. As the calculation progresses, then the values of y will need to be updated depending on your independent variable, which I assume would be time.
