Projectile motion with friction in MATLAB (ODE45)
The discussion revolves around modeling the motion of a projectile with air resistance in MATLAB using the ODE45 function. Participants explore the formulation of the equations of motion, the inclusion of air resistance proportional to the velocity squared, and the challenges of defining a function for ODE45 due to interdependent variables.
  • One participant presents equations of motion for a projectile considering air resistance, defined as proportional to the square of the velocity.
  • Another participant points out that the presented equations are not in the form suitable for ODE45, which requires a system of differential equations.
  • There is a reiteration that the equations need to be reformulated to express the derivatives of position and velocity with respect to time.
  • A suggestion is made to define the function for ODE45 using an array that includes position and velocity components, but the provided code does not align with the original problem's parameters.
  • One participant acknowledges the need to update the values of B, which depends on the height y, as the calculation progresses over time.
Participants generally agree on the need to reformulate the equations for use with ODE45, but there is no consensus on the correctness of the initial equations or the specific implementation details for the function.
There are unresolved aspects regarding the proper formulation of the equations of motion and the implementation of the function for ODE45, particularly how to handle the dependency of B on y during the calculations.
cwrn
I'm working on a little project where I want to plot the motion of a projectile with air resistance. The air resistance can be assumed to be proportional to the velocity squared.
[itex]F_{f}=-Bv^{2}[/itex]
[itex]F_{f,x}=F_{f}\frac{v_{x}}{v}, \ \ F_{f,y}=F_{f}\frac{v_{y}}{v}[/itex]
where B depends on the height, y above the ground
[itex]B(y) = B_{0}e^{-y/y_{0}}[/itex]
Given
[itex]k = \frac{B_{0}}{m}=4\cdot 10^{-5} \ m^{-1}, \ y_{0} = 1\cdot 10^4 \ m, \ v_{0} = 700 \ m/s[/itex]
I have derived the equations of motion as following:
[itex]\vec{r}=\left(v_{0}tcos\theta-\frac{1}{2}kvv_{x}e^{-y/y_{0}}\cdot t^2\right)\hat{i}+\left(v_{0}tcos\theta+\frac{1}{2}\left[\vec{g}-kvv_{y}e^{-y/y_{0}}\right] t^2\right)\hat{j}[/itex]
[itex]\vec{v}=\left(v_{0}cos\theta-kvv_{x}e^{-y/y_{0}}\cdot t\right)\hat{i}+\left(v_{0}sin\theta+\left [\vec{g}-kvv_{y}e^{-y/y_{0}}\right]t\right)\hat{j}[/itex]
[itex]\vec{a}=\left(-kvv_{x}e^{-y/y_{0}}\right)\hat{i}+\left(\vec{g}-kvv_{y}e^{-y/y_{0}}\right)\hat{j}[/itex]
I'm having trouble defining a function I can use with ode45 since there are several variables depending on each other (assuming my equations are correct). Any tips would be greatly appreciated.
I haven't checked if the equations are correct, but they are not differential equations!
What you need for ode45 is something like
\begin{align}
\frac{dx}{dt} &= v_x \\
\frac{dy}{dt} &= v_y \\
\frac{dv_x}{dt} &= a_x \\
\frac{dv_y}{dt} &= a_y
\end{align}
where you replace ##a_x## and ##a_y## by the proper expressions involving the forces.
\begin{align}
\end{align}
Yes, I'm aware of this. Solving this with ode45 should yield the x and y vectors that I want to plot. I'm just not sure how to define the function itself since it depends on B which in turn depends on y.
\begin{align}
\end{align}
If you take the array y to contain ##(x,y,v_x,v_y)##, then you would write something like
Code:
function dy = projectile(t,y)
B0 = 1;
y0 = 123;
dy = zeros(4,1);    % a column vector
dy(1) = y(3);
dy(2) = y(4);
dy(3) = B0 * exp(-y(2)/y0) * y(3);
dy(4) = B0 * exp(-y(2)/y0) * y(4);
(Note that the code doesn't correspond to your problem.)
\begin{align}
\end{align}
You start off your calculations with a known position for the projectile, which means you are going to know an initial value for y. As the calculation progresses, then the values of y will need to be updated depending on your independent variable, which I assume would be time.
