Projectiles: Launch speed and horizontal distance
2 replies · 6K views
gratsoy
New to the forums, just starting a physics 11 course online and having some troubles with formulas.
Projectile shot straight upwards, flight time = 4.70 sec
Second Launch at 45 degrees (horizontal range approx. 50-60 meters
A) Find Launch Velocity
B) Find Horizontal Range when shot at 45 degrees
d = vit +1/2gt2
V = - 1/2gt ("made" this one myself from above formula, unsure if correct)
Launch velocity
V = - 1/2gt
g = -9.8m/s
t = 4.7s
V = -[((1/2(-9.8))(4.7)]
V = -((-4.9)(4.7))
V = 23.0 m/s
I have no idea how to calculate the horizontal range, I need a formula that incorperates the 45 degrees
Thanks in advance!
d = vit +1/2gt2
Launch velocity
V = - 1/2gt
g = -9.8m/s
t = 4.7s
V = -((-4.9)(4.7))
V = 23.0 m/sI have no idea how to calculate the horizontal range, I need a formula that incorperates the 45 degrees
Thanks in advance!
You can work from first principles: Calculate the vertical and horizontal components of the launch speed - using sin45 and cos 45 factors.
The vertical component let's you calculate the flight time, the horizontal component with that time let's you calculate how far away it will land - the range.
Many Physics texts will have a section where a formula is derived, so you can simply substitute the 23 m/s to get an answer [assuming 23 m/s is correct - it certainly is a reasonable answer]
How would I do this? I am completely new to this and need a formula with a simple step-by-step guide on how to implement that formula to derive the answer.
