Proof by Induction Involving Divisibility
5 replies · 2K views
Colleen G
Let P(n): 7|(34n+1-52n-1. Prove that P(n) is true for every natural number n.
*I know that proving by induction requires a proving P(1) true, and then proving P(k+1) true.
*If a|b, then b=a*n, for some n∈ℤ
I have proved the "base case" for P(1). Long story short, for n=1, you wind up with 7|238 by definition of divisibility since 238=7(34). So P(1) is true.
The next part is where it gets tricky - Assuming P(k) is true, that is, 7|(34k+1-52k-1, which is the inductive hypothesis. Then proving for P(k+1). What I have so far is...
7|7|(34(k+1)+1-52(k+1)-1
=34k+5-52k+1
=34 * 34k+1-51*52k
=34 * 34k+1-(3*52k+2*52k)
=34 * 34k+1-3*52k-2*52k
Now I don't know what to do! I know I have to get it to the point where I can use the inductive hypothesis, which is what I'm trying to do, but I've hit a wall, or taken a wrong turn when split the 5 into a two and a three. Any ideas?
=34k+5-52k+1
=34 * 34k+1-51*52k
Here's a short hint 3^4=81=56+25=56+5^2 and 56 is divisible by 7.
Ok yes I see that, but am having trouble using it. Are the steps that I have taken so far correct? Or have I done more than necessary. What I'm saying is, can I use this information about 3^4 from the step that I left off at?
Convince yourself that ##P(k+1)=81*3^{4k+1}-25*5^{2k-1}##. Use that ##81=56+25##. See how you can express that in terms of ##P(k)##?
=34k+5-52k+1
=34 * 34k+1-51*52k
This is badly written: the "equation" you wrote, namely
[tex]7|7|(3^{4(k+1)+1} - 5^{2(k+1)-1} \\<br /> = 3^{4k+5} - 5^{2k+1} \\<br /> \vdots[/tex]
does not even make sense.
To say it properly, here is a hint: letting ##F(n) = 3^{4n+1} - 5^{2n-1}##, prove that for positive integer ##k##, ##F(k) = 7j## for some positive integer ##j## implies ##F(k+1) = 7 m## for some positive integer ##m##.
Thank you for you help, Dick! I understand now.
