Proof: every convergent sequence is bounded
8 replies · 17K views
SpY]
Prove that every convergent sequence is bounded.
Definition of [tex]\lim_{n \to +\infty} a_n = L[/tex]
[tex]\forall \epsilon > 0, \exists k \in \mathbb{R} \; s.t \; \forall n \in \mathbb{N}, n \geq k, \; |a_n - L| < \epsilon[/tex]
Definition of a bounded sequence: A sequence is bounded iff it is bounded above and below, ie. [tex]\exists m \in \mathbb{R} \; s.t. a_n \geq m \; \forall n[/tex] and similarly [tex]a_n \leq M[/tex]
2. The attempt at a solution
Suppose a sequence [tex]a_n[/tex] converges to some limit L.
Then by definition of the limit [tex]\forall \epsilon > 0, \exists k \in \mathbb{R} \; s.t \; \forall n \in \mathbb{N}, n \geq k, \; |a_n - L| < \epsilon[/tex]
Rewriting the absolute value, [tex]L - \epsilon < a_n < L + \epsilon[/tex]
Since [tex]L, \epsilon \in \mathBB{R}[/tex], [tex]L + \epsilon > a_n \; \text{and} L - \epsilon < a_n[/tex]. So the sequence is bounded above and below, hence bounded.
In my lecture notes, the given proof chooses [tex]\epsilon = 1[/tex] but does this affect the proof since [tex]\epsilon[/tex] is arbitrary? It is also written as [tex]\left \{ a_n : n \leq k \right \} \subset (L-1, L+1)[/tex] but my notation is equivalent?
You can choose any [itex]\epsilon[/itex] you like. The resulting k will be different depending on which [itex]\epsilon[/itex] you choose, but that doesn't matter. All you need is a specific pair of [itex]\epsilon[/itex] and k that work.
Yes, these two notations mean the same thing:
[tex]\{a_n : n \geq k\} \subset (L - 1, L + 1)[/tex]
and
[tex]\forall n \in \mathbb{N}, n \geq k, \; |a_n - L| < 1[/tex]
The basic problem with your proof is that you aren't using logical quantifiers properly. In statements about variables, a sentence at the top of the page may say something about [itex]\epsilon[/itex] and later sentence may mention [itex]\epsilon[/itex], but the two [itex]\epsilon[/itex]'s need not have anything to do with each other. Each use of a variable should occur with the "scope" of a certain quantifier.
You go from this statement:
To
Without making it clear that you wish to pick a particular [itex]\epsilon[/itex] from among the possibly thousands of different ones that exist. There is actually a name for this procedure. As I recall, the author Irving Copi called it something like "existential instantiation". It says if we know "there exists" a variable with certain properties, we may introduce a variable that is one particular instance.
You also aren't doing a good job with [itex]n[/itex]. In the definition of bounded the quantifier is "for all" [itex]n[/itex] and in the definition of limit the condition is "for all [itex]n \ge k[/itex]". The two statements are not about the same [itex]n[/itex].
Once you pick a particular [itex]\epsilon[/itex], the definition of limit is going to get you
[tex]L - \epsilon < a_n < L + \epsilon[/tex] for all [itex]n \ge k[/itex] , but not "for all [itex]n[/itex] ".
For example, [itex]L + \epsilon[/itex] doesn't work for a upper bound because for some [itex]j < k[/itex] we can have [itex]a_j > L + \epsilon[/itex]. So you should define [itex]M[/itex] as the larger of: [itex]max \{a_j: j < k \}[/itex] and [itex]L + \epsilon[/itex].
Note that [itex]a_{n}=a_{n}-a+a[/itex], and so that:
[tex] |a_{n}|\leqslant|a_{n}-a|+|a|[/tex]
From here, I think that you can show that all convergent sequences are bounded.
Although I don't really see the need to choose an [itex]\epsilon[/itex], I understand why for clarity it makes sense to chose one. I thought that proving that there exists some k for which an is bounded would be sufficient, but I see now one has to consider a set of [itex]{a_n : n < k}[/itex] then use the fact that the union of bounded sets is bounded.
Thanks
This is that quantifier problem. The epsilon interval only gives you a bound for some of the terms.
Also, at some initial point, you must *clearly fix* an epsilon. It's nice to make that concrete, particularly if you have to use it to prove something further down the road, hence choose it to be simply 1.
I agree that it isn't necessary to state a numerical value for [itex]\epsilon[/itex]. It is necessary to state that a specific [itex]\epsilon[/itex] is being chosen, even if it is represented only as a symbol.
If you don't pick a specific [itex]\epsilon[/itex] then what would the expression [itex]L + \epsilon[/itex] stand for? Would we interpret it as an infinite set of numbers formed by adding [itex]L[/itex] to each possible [itex]\epsilon[/itex] ? If we interpret it that way then it's doesn't help us find an upper bound since an upper bound is supposed be a number, not an infinite set of numbers.
No. Treat the epsilon as an arbitrary fixed number greater than 0. Similary, you can represent an even number a as a = 2k, where k is an integer. We have a fixed value of k. We don't treat this as all integers k.
"Fixed" is the same as saying that [itex]\epsilon[/itex] has been chosen to be specific.
