Proof of discontinuity at a point using diameter (in a metric space)
8 replies · 3K views
Pen_to_Paper
X, Y are metric spaces and f: X [tex]\rightarrow[/tex] Y
Prove that f is discontinuous at a point x [tex]\in[/tex] X if and only if there is a positive integer n such that diam f(G) [tex]\geq[/tex] 1/n for every open set G that contains x
diameter of a set = sup{d(x,y): x,y [tex]\in[/tex] set}
sup exists if a set is bounded (here, is our set f(G)?)
I'm not understanding "...diam f(G) [tex]\geq[/tex] 1/n..."
should our diameter, in this case, read:
diam f(G) = sup{d(x,f(x)): x, f(x) [tex]\in[/tex] the set} ??
or am I mixing up f(G) and f(x)?
f(x): X[tex]\rightarrow[/tex]Y
f(G) = ??
G is an open set that contains x
G={x: x [tex]\in[/tex] R, the reals, for which f(x) is discontinuous}
does that mean f(G) is just an x = f(G) mapping of these discontinuous x's (discontinuous on f: X [tex]\rightarrow[/tex]Y) ? (what i mean by mapping is, should I be thinking of f(x) as a graph like y=x? where f(G)= x? )
I'm thinking of an example like this:
f: X[tex]\rightarrow[/tex]Y
f(x) = 1/ (x-1)*(x-2) (discontinuous at x=1, x=2)
G-sub1={1}
G-sub2={2}
I don't know what f(G) is; is it f(1)=1? does f(2)=2? so I'm not sure how to relate it to the diameter, namely f(G) [tex]\geq[/tex] 1/n
I'm doing this example just to try and see what's going on with the terms, not because the proof is going to include the function i presented here (obviously)
Am I thinking of this the wrong way? I know the proof will be in more general terms but I'm not sure what to do with the diam f(G) [tex]\geq[/tex] 1/n for n, a positive integer
If someone can point me in the right direction or just explain it - I think once diam f(G) [tex]\geq[/tex] 1/n is clarified, I can work through the rest of the problem, namely the general proof. I asked my professor about it today - I told him I didn't understand the diam part - and he sort of looked at me like I had grown a third head. Is this some very obvious definition I have missed? I'm using Rudin by the way, only at chapter 5.
Thank you for any insight!
f(G) is just the set of all images of elements in G. Precisely:
[tex]f(G)=\{f(x)~\vert~x\in G\}[/tex]
This is a set in the codomain. So you can take the diameter of this set. Explicitely this yields
[tex]diam f(G)=\{d(f(x),f(y))~\vert~x,y\in G\}[/tex]
Hope this helps...
micromass, thank you for the quick reply, but I'm not sure what the y and f(y) are in the diam f(G) equation
is it a way of saying f(x)=y ( the function going from metric space X to Y) ?
but then, what is f(y)?
Separately, if G is the set of all x discontinuous on f, then isn't f(G) undefined? why is it greater than or equal to 1/n ?
Again, thank you for taking the time to respond!
Nonono, our y is just an element of X, it has nothing to do with f. Would it help you if I wrote
[tex]diam f(G)=\{d(f(x),f(x^\prime))~\vert~x,x^\prime\in G\}[/tex]
So let's take some examples.
Let G=]0,10[ and let [tex]f(x)=x^2[/tex]. Then f(G)=]0,100[. The diameter of f(G) is then 100.
But if [tex]f(x)=1/x[/tex], then [tex]f(G)=]1/10,+\infty[[/tex]. Thus the diameter of f(G) is infinite.
I'm not sure why you want to take G the set of all discontinuities. I can't see how that helps.
Secondly, if you take G the set of discontinuities, then G is not necessairily open...
"I'm not sure why you want to take G the set of all discontinuities. I can't see how that helps.
Secondly, if you take G the set of discontinuities, then G is not necessairily open... "
I want to take G (the set of discontinuities) because I thought I was using G, namely f(G), for the diam f(G) >= 1/n for every open set G that contains x; that is the wording of the original question
And secondly, you are probably right about G not necessarily being open; in fact when I asked my professor about this, he seemed to imply this in his explanation.
The original question is this:
"X, Y are metric spaces and f: X LaTeX Code: \\rightarrow Y
Prove that f is discontinuous at a point x LaTeX Code: \\in X if and only if there is a positive integer n such that diam f(G) LaTeX Code: \\geq 1/n for every open set G that contains x"
But now with your information about G not necessarily being open, does that my original function from X -> Y will only be discontinuous at x if x is contained in an open set G?
I have another question pertaining to this problem and the last response from micromass
the original problem asks us to prove that f is discontinuous at x iff there exists a positive integer n such that diam f(G)>= 1/n for every open set G, and in the last response, micromass has f(x)=1/x and I'm wondering if this by mistake or if this is the way I should be interpreting the problem? because x can be any real number, but n was specified as a positive integer... HELP!
Oops! I mean to say the original problem is this:
Pen_to_Paper said:
1.
I don't see where you get that from...
No, you need to prove your problem for positive integers. You probably misunderstood my example. The f(x)=1/X has nothing to do with diam f(G)>= 1/n
Let's guide you in the right direction. You have an f which is discontinuous at the point x, what does this mean??
You'll need to prove something about open sets containing x. What is an open set?
ok, here is my problem, i know the delta-epsilon proof for continuity;
f is continuous at every point p if there exists an epsilon>0 such that delta>0
and I don't know the logic principles well enough to construct a way to disprove it. Is it:
for every epsilon there exists a delta>0 such that |y-x|<delta ?but I have no idea how to relate all of this to an open set
f is continuous in a means that
[tex]\forall \epsilon>0:~\exists \delta > 0: \forall x\in X:~|x-a|<\delta ~\Rightarrow~|f(x)-f(a)|<\epsilon[/tex]
Negating a statement is done by inverting the kwantors and negating the statement after the kwantors. Thus this would be
[tex]\exists \epsilon >0:~\forall \delta >0:~\exists x\in X:~|x-a|<\delta ~\text{and}~|f(x)-f(a)|\geq \epsilon[/tex]
