Proof of Infinite Set of Real Numbers Between Two Unequal Real Numbers
  • Context: Undergrad
  • Thread starter Thread starter RandomAllTime
The discussion revolves around the proof of the existence of an infinite set of real numbers between any two unequal real numbers. Participants explore the validity of a proposed proof and engage in a critique of its structure and assumptions. The conversation includes elements of mathematical reasoning, proof writing, and foundational properties of real numbers.
  • One participant presents a proof involving an infinite sequence of real numbers between two unequal numbers but faces criticism regarding the lack of clarity and correctness in the sequence's definition.
  • Another participant points out that the proposed sequence does not necessarily lie within the interval defined by the two numbers, highlighting an assumption that needs to be proven.
  • Several participants suggest starting with the Archimedean property and the density of rational numbers as a foundational approach to the problem.
  • Some participants discuss the concept of density in the context of real numbers and rational numbers, proposing alternative proofs and methods to demonstrate the existence of infinite numbers between any two real numbers.
  • There is a mention of the importance of providing proofs of existence and uniqueness when making mathematical claims.
  • Participants express interest in improving mathematical notation and proof writing skills, suggesting resources for learning LaTeX.
  • One participant speculates about the nature of real numbers as a fractal-like structure, proposing a conceptual visualization of their density.
Participants express a mix of agreement and disagreement regarding the initial proof and its assumptions. While some suggest alternative approaches and foundational properties, there is no consensus on the validity of the original proof or a definitive resolution to the discussion.
Participants note the importance of clarity in mathematical discourse, particularly regarding the definitions and properties of sequences and intervals. There are unresolved issues related to the assumptions made in the original proof and the need for rigorous justification of claims.
This discussion may be useful for individuals interested in mathematical proof writing, the properties of real numbers, and foundational concepts in mathematics, particularly those at the beginner or intermediate level.
RandomAllTime
Hello everybody, I seek the analysis and criticism of mathematicians. I'm sure this has already been proven a while ago, but I wrote a proof that there is an infinite set of real numbers between any two real numbers provided they are unequal. I am not yet in college and I lack proper training in proof writing, so I come here to show you the proof and gather whether or not you think it is valid, or if it is broken and or needs revision. Thank you. Perhaps even my assumption is wrong. I am just a beginner who is trying to develop proof writing skills, so please excuse any trivial errors, but please do tell of them. Here is what I have come up with. It is quite short and simple.
Consider the closed interval [a,b], where a≠b and a,b ∈ ℝ.
Next consider the infinite sequence S = [/0], [/1], [/2], ... such that [/1] > a and limS = b.
The set of all terms in S shall be denoted X = {s|s∈S}
Since X is a subset of all the real numbers between a and b, and X is infinite, the set between any two real
numbers a and b is infinite.
Thank you.
That's very difficult to understand. Apparently you are trying to prove that there are an infinite number of real numbers between any two numbers, a and b. You start by saying "consider the infinite sequence S = [/0], [/1], [/2], ... such that [/1] > a and limS = b." and then conclude that the infinite set of numbers in that sequence are in the interval [a, b]. That is NOT true because you do NOT require that the numbers in the sequence be less than b.
For example, taking a= 1, b= 2, and the sequence to be 2+ 1/(n+1) satisfies all of conditions you give but none of the numbers in the sequence are in [1, 2]. You are assuming, without saying it, that your sequence lies in the interval [a, b] but that assumes what you purport to prove.
I'm sorry. I screwed up with the subscript notation (I'm new to it). I was trying to convey that S={s(subscript 0),s(subscript 1), ...} and that s(subscript 0) > b. I imagine my posted version looked quite ridiculous. Thank you.
There are a couple of rules of mathematical discourse that sometimes go unstated:
If you say "a <something>" then you have to be able to produce a proof of existence. You have to be able to demonstrate that at least one such something exists.
If you say "the <something>" then you have to be able to produce a proof of existence and uniqueness. You have to be able to demonstrate that at least one such something exists. And you have to be able to show that there is only one.
In the original post above you refer to "the infinite sequence S...". But no proof of either existence or uniqueness is provided.
Hmmm, not the funniest thing to do during summer time :wink:
This is where you should start : https://en.wikipedia.org/wiki/Archimedean_property
Then you will try to prove that between any 2 real number, there is a rational number. By induction, you will deduce that there is an infinite sequence of rational number between 2 real number, thus proving your property. This famous property is called "density of ##\mathbb{Q}## in ##\mathbb{R}##".
Ok, thank you very much.
Ah, I see. Thank you :)
Thank you all for the feedback, and please excuse my messed up notation in the original post.
The Archimedean property is definitely overkill here since the same result is true for non-Archimdean fields. In fact, an easy proof just uses the sequence of successive averages:
[tex]a_0 = a,~a_1 = b, ~a_2 = \frac{a + b}{2},..., a_n = \frac{a_{n-1} + a_{n-2}}{2},...[/tex]
Have to agree with @micromass.
The infinite density of the reals in more detail: http://www.abstractmath.org/MM/MMRealDensity.htm
definitely agree with you :biggrin:
If you are really interested in this stuff (math I guess?) it is a good idea to learn LaTeX. It will help you on this site and it will help you in college. If you are still in HS, it isn't really important, but it also isn't really that hard to pick up the basics.
Thanks, will do.
Thanks, very interesting read.
Huh, maybe I'm wrong, but it's interesting to think of ℝ as a sort of fractal object. I mean, as you zoom in there will be infinite line division. The vertical length of line division n would be equal to |n|. The integers can be the taller line divisions while the non integer reals are smaller and make up the infinite space inbetween them. Also, maybe the different types of line divisions could have a different color scheme, like the primes be blue, and whatnot. The point zero would be like the middle between these two "elephant ear" type shapes which would be the negative and positive sides. Just an abstraction I find interesting. What do you guys think?
I think that you have excellent intuition, and that the intuition is anticipating that that fractals are a mathematical construct that build upon the infinite density property of the reals. Hmmmm. Certainly what most of us visualize when we hear the world 'fractals' (see https://en.wikipedia.org/wiki/List_of_fractals_by_Hausdorff_dimension) is topological in nature and requires a mapping of the Reals onto a space. I think the Extended Real Number Line fails to be a fractal because of the requirement that by definition a fractal (L. fractus, broken) has to have a non-integer dimension. The ERNL by definition has a dimension of 1. If you look at the list to which I've linked above, you'll see that the Cantor set (which is a subset of the ERNL) is a subset of the Reals which does qualify.
You seem to be genuinely interested in mathematics for its own sake. How motivated are you to learn and do math? I ask because I'm an ex-teacher (computer science and math), and I wanted to undertake a bit of a math project online and would be interested in your curiosity and skills. If you're really like me (I can never get enough of math), it might be some good experience for you.
Thank you for the compliment and the wonderful input! I'll be sure to check that out. I would also like to hear about your project.
