Proof of Prime Number: Beginner's Guide
  • Thread starter Thread starter Black Orpheus
    Prime Proof
The problem involves demonstrating that a positive integer q, which satisfies the condition that if q divides the product ab, then q must divide either a or b, is a prime number. Participants are exploring the implications of this condition and the definitions surrounding prime numbers.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the definition of prime numbers and the implications of the given condition. Some suggest using the contrapositive approach to explore the relationship between q being prime and the divisibility condition. Others question the assumptions made about the integers a and b in relation to q.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have offered guidance on how to approach the proof, particularly through the contrapositive method, while others are questioning the validity of certain assumptions and definitions provided in earlier posts.
There is some confusion regarding the definitions of prime numbers and the conditions under which the divisibility statement holds. Participants are also addressing potential counterexamples, such as q=6, to illustrate their points.
Black Orpheus
1. Here is the problem I'm stuck on:
Let q be a positive integer, q is greater than or equal to 2, let a and b be integers such that if q divides ab, then q divides a or q divides b. Show that q is a prime number.
2. I know that q is prime if and only if 1 divides q and q divides q.
3. I don't really know where to begin. Where might I go from here?
You want to show that if q is such that whenever q divides ab, q divides a or q divides b, then q must be prime. One way to do this is to show that if q is not prime, then it is not true that whenever q divides ab, q divides a or q divides b. Do you see why this is the same thing? This is called the contrapositive of the original statement.
Notice that "if q divides ab then q divides a or q divides b" must be true for all numbers a, b. Suppose q was not prime. Can you use that to construct numbers a, b such that "q divides ab but q does not divide a or b separately". The easiest case to try is q= 6.
If I assume that q is prime, then that implies that there exist two integers ab such that q divides ab. It also must mean that a and b are both greater than 1 and less than q. If this is the case, then q does not divide a and q does not divide b (contrapositive: if q is not prime, then q divides ab implies q does not divide a and q does not divide b). Therefore p is prime?
Just to nitpick a little bit (maybe a lot..) that definition can't be exactly right since it is trivially true for all integers.
In other words it is true for all integers n that 1|n and n|n. You need to modify the definition to say something along the lines of that 1 and n are the only divisors or n, and n is not equal to 1.
??Given any integer q, there certainly exist many integers a, b such that q divides ab. That's not the point!
No, there is nothing said here requiring that a and b be less than q. Indeed, if q divides either a or b, then one of them must be at least as large as q.
?? Where did p come from?? Did you mean "q". If so, you started by saying "If I assume q is prime". What you have proved is "If q is prime, then q is prime"! No, what you give is not the contrapositive of the statement you want to prove- because the statement you give is NOT true.
One more time- you have misstated the problem itself:
is not true.
For example q= 6 is NOT a prime number but a= 5, b= 12 are numbers such that "if q (6) divides ab (60) then q divides a or q divides b (6 divides 12)".
What you want to prove is
Let q be a positive integer, q is greater than or equal to 2, such that for any integers, a, b, such that q divides ab, then q divides a or q divides b. Show that q is a prime number.
As you have been told, it is sufficient to prove the "contrapositive": "if there exist integers a,b such that q divides ab but q does not divide either a or b." Suppose q= 6. Can you find a, b such that 6 divides ab but does not divide either a or b?
