Proof on boundedness of sets in n space
  • Thread starter Thread starter prettymidget
    Proof Sets Space
11 replies · 2K views
prettymidget
Let S be a bounded set in n -space. Fix a d>0. Then it is possible to choose a finite set of points {pi...pm} in S such that every point p in S is within a distance d of at least one of the points p1, p2,...pm.
None really.
I've tried some methods but I have been stuck at some point of every attempt. A nudge (or two) in the right direction would be greatly appreciated.
This is exactly how its written and that's all they gave.
as a start you could consider 2 cases, where the bound on S is less than d and when it is greater...
How much point-set topology do you know? I've got a proof, but it uses a property of compact spaces that you may not be expected to know.
What property of compactness did you need? Here is an idea that might nudge you in the right direction. Consider the special case of R, which is one-dimensional. Since S is bounded, it lies entirely between -M and M for some M. Certainly, if d >= 2M, we need just pick any point in S to be done. Every other point is within a distance 2M from that point. What if d = M? A first thought might be to choose the midpoint... but that might not be in S. How can we compensate?
Basically just the definition: Any open cover of a compact set has a finite subcover. To get a compact set, take the closure of S; to get an open cover, consider the union of all balls of radius d around every point in S...
That is pretty slick. Occasionally I have these bouts where I realize I'm in out of my depth and don't know enough in this case about metric spaces. I know that in Rn compactness isn't needed (at least not directly). But now I'm not so sure about arbitrary metric spaces.
It's not true for an arbitrary metric space. Think about the unit sphere in an infinite dimensional Hilbert space, or even simpler any space with an infinite number of elements with a discrete metric.
I don't know much topology, only the basic concepts and definitions such as limit point, open closed sets, boundary, closure, and such. The class is a multivariable analysis class, so only basic knowledge has been needed so far.
I actually asked my TA the question and the proof he gave was very long and something that didn't even look undergraduate level to me. If you've found a proof using basic concepts I would appreciate it greatly if you would post it. I haven't really been able to dent the problem.
I'm not sure. I thought about the problem a lot and I was completely convinced that the set S need be both bounded and closed for the rest to follow, so its limit points would be contained in the set.
If the set in contained in Euclidean n-space, then there is a way to prove it that doesn't require any topology at all. Practice by supposing n=2. Hint: for any bounded set you can pick a number S such that the set in contained in a square with side length S centered at the origin. Now pick a d>0 and describe a finite set of points that works.
