Proof that (n+1)/(3n-1) converges to 1/3
  • Thread starter Thread starter kolley
    Proof
3 replies · 6K views
kolley
prove (n+1)/(3n+1) converges to 1/3
I have been trying to figure this out for a while. I started out
(n+1)/3n+1)-1/3=(2n+2)/(9n-3) now I don't know how to proceed with the proof. What do I set N equal to? And then how do work it back into my inequality chain? Working this out step by step would be greatly appreciated.
how does L'Hopital's rule get incorporated into a formal proof for a sequence converging. I don't understand
Are you required to use an "N-[itex]\epsilon[/itex]" proof? If not, then you can use L'Hopital's rule- although even then, I would consider it "overkill". If you are not required to use L'Hopital, just divide both numerator and denominator by n and use the fact that [itex]1/n\to 0[/itex] as n goes to infinity.
If you are required to use "N-[itex]\epsilon[/itex]":
To start with you are completely wrong in saying that (n+1)/3n+1)-1/3=(2n+2)/(9n-3). I presume the denominator, 9n-3 instead of 9n+3, is a typos but even so,
[tex]\frac{n+1}{3n+1}- \frac{1}{3}= \frac{3(n+ 1)- (3n+1)(1)}{3(3n+ 1)}= \frac{3n+ 3-3n-1}{9n+ 3}= \frac{2}{9n+1}[/tex]
That is, you need to make
[tex]\left|\frac{n+1}{3n+1}- \frac{1}{3}\right|= \frac{2}{9n+1}< \epsilon[/tex]
it should be easy to continue from there.
