MHB Can we prove that (m+1)/(n+1) > m/n if n>m>0 using synthetic proof?
The discussion focuses on proving that (m+1)/(n+1) > m/n given that n > m > 0. Participants explore examples to identify patterns and derive a proof using algebraic manipulation. The key steps involve calculating the difference between the two fractions and demonstrating that both the numerator and denominator remain positive under the given conditions. By reversing the proof process, it is shown that if n > m, then the inequality holds true. The concept of synthetic proof is emphasized as a method to validate the conclusion without needing to explicitly show every step in reverse.
EqualElement
Let m,n be real numbers. Prove that if n>m>0 , then (m+1)/(n+1) > m/n
I'm currently confuse in this one help will be very much needed
How are you confused?
I understand the question but don't really know how to prove it.
Let's start with several examples. What do you choose for n and m which m must be bigger than n and be positive for both (m and n)?
okay m=1 , n=2 would make it true.
Any other example? Just keep making examples to see a pattern...
m=2, n=3
m=3, n =4
m=12, n=69.
let us calculate $\frac{m+1}{n+1}- \frac{m}{n}$
= $\frac{n(m+1) - m(n+1)}{m(n+1)}$
= $\frac{n - m}{m(n+1)}$
as n > m >0 so both numerator and denominator positive and hence
$\frac{m+1}{n+1}- \frac{m}{n}> 0$
or $\frac{m+1}{n+1}> \frac{m}{n}$
Since m and n are positive numbers, so are n and n+ 1 so you can eliminate the fractions by multiplying both sides by n and n+ 1 without changing the inequality.. That gives you n(m+1)> m(n+1) so that nm+ n> mn+ m. Can you finish?
What I showed above was that "if $\frac{m+1}{n+1}> \frac{m}{m}$ then n> m. What you want to prove is the other way around- just reverse every step. From n> m, mn+ n> mn+ m.
n(m+1)> m(n+ 1). Dividing both sides by the positive number n and n+ 1, $\frac{m+1}{n+1}> \frac{m}{n}$.
It is often useful to see how to prove something by working backward, from the conclusion to the hypothesis. As long as every step is "reversible", it isn't necessary to actually show the reverse. That is called "synthetic proof".
  • · Replies 29 ·
  • · Replies 22 ·
