Proper distance vs comoving distance in GR
  • Level: Graduate
  • Thread starter Thread starter pervect
    Gr Proper distance
97 replies · 20K views · last reply
yuiop said:
Now if I set r0 = infinite in your equation, it reduces to:
[tex] \frac{dr}{dt} = \sqrt{\frac{2m}{r}(1-v_0^2) +2mv_0^2} [/tex]
which does not agree with either the mathpages coordinate velocity or proper velocity:
You might want to double check that.
I get:
[tex] \sqrt {2m \left( {r}^{-1}-{\frac { \left( -r+1 \right) {{\it <br /> v_0}}^{2}}{r}} \right) }[/tex]
yuiop said:
The local velocity of a falling particle with initial velocity v0 at infinity, according to an observer at r, was derived in #79 and is:
[tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-v_0^2) +v_0^2} [/tex]
This formula is identical to mine if we take r0 = infinity.
This is identical:
[tex] \sqrt {{v_0}^{2}+{\frac {1-{v_0}^{2}}{r}}}=\sqrt {{r}^{-1}-{\frac {<br /> \left( -r+1 \right) {v_0}^{2}}{r}}}[/tex]
yuiop said:
[tex] \frac{dr single-quote}{dt single-quote} = \sqrt{\frac{2m(r^{-1} - r_0^{-1})}{(1-2m/r_0)}} [/tex]
It looks like you are right on that one.
I get:
Starting with your equation:
[tex]\Rightarrow \sqrt {\frac{2m}{r}-\frac { 2m\left( -r+1 \right) <br /> v_0^2}{r}} [/tex]
[tex]\Rightarrow \sqrt {\frac{2m}{r} +2mv_0^2-\frac { 2mv_0^2}{r}} [/tex]
[tex]\Rightarrow \sqrt {\frac{2m}{r}(1-v_0^2) +2mv_0^2}[/tex]
So we both get the same result for the reduction of your equation when r0 = infinite, and this does not agree exactly with the equation I gave in #89:
[tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-v0^2) +v0^2} [/tex]
Do you now at least agree that the equations I gave in #89 are correct?
I note that sometimes you are explicitly using rs = 2m and other times using rs = 1 which might lead to errors.
Your generic equation is close for the r0 = infinity case if we only use rs =1 but it is miles out for the v0 = 0 and r0<infinite case.
Ok, let's take a look at the formulas you presented.
When I enter m=1/2, v0=1/2 and r=1 I get a v>1 this does not seem right. In fact v reaches 1 already at r=4/3 using your formula. Unless I am mistaken v=1 should only happen at the EH. My formula gives v=1 at r=1.
yuiop said:
I note that sometimes you explicitly using rs = 2m and other times using rs = 1 which might lead to errors.
Yes, I apologize for that, I changed many formulas around to express them in terms of m instead of rs but some have not been updated.
I am not sure how you get that result. I get:
[tex] \frac{dr'}{dt'} = \sqrt{\frac{2m}{r}(1-v0^2) +v0^2} = \sqrt{\frac{1}{1}(1-(0.5)^2) +(0.5)^2} = \sqrt{1-0.25 + 0.25} = 1[/tex]
Try your formula:
[tex] <br /> \frac(dr'}{dt'} = \sqrt {2m \left( {r}^{-1}-{\frac { \left( -r+1 \right) {{\it <br /> v_0}}^{2}}{r}} \right) }<br /> [/tex]
using m=7, r=2m and v0 =1/2 and you will see where the problem is. (My (mathpages) equation works for any arbitrary value of m.)
Try your formula:
[tex] <br /> \sqrt {2m \left( {r}^{-1}-{\frac { \left( -r+1 \right) {{\it <br /> v_0}}^{2}}{r}} \right) }<br /> [/tex]
using m=7, r=2m and v0 =1/2 and you will see where the problem is. (My equation works for any arbitrary value of m.)
Sorry yuiop I am definitely not having my day, must be my jet lag due to moving from China to the USA.
Ok, now I think your formulas look good, I am going to play with them a little. Would it be possible to get a generic "Fermi distance formula"? I am going to take your formulas to get a generic distance formula as well.
Ok, here are the plots for the formulas you presented, and they look good. One thing is very different, the 'dropped from a r value' observers. In my plot the distance decrease is definitely not linear while using your formulas it appears linear. But I think yours are correct and mine were wrong.
In the last graph the stationary observers are obviously not in motion so each point on the plot represents a different observer at a different r value.
The paramaterized equations for a general spacelike geodesic will be given by the functions r(s) and t(s) that satisfy
[tex] \frac{dt}{ds} = \frac{C}{1-2m/r}[/tex]
[tex] \left(\frac{dr}{ds}\right)^2 = 1 + C^2 - 2m/r[/tex]
where C is an arbitrary constant. To get the fermi-normal distance associated with the worldline of some particular time-like observer, you'll have to choose the correct value of C so that your geodesic is orthogonal to the worldline of your time-like obsever at the point where they cross.
Can anyone suggest me any book to start with general theory of relativity and cosmology?
Can anyone describe me simplest way that what the general theory relativity acutually tell.
