Proportionally damped 2-DOF system
  • Thread starter Thread starter toaster89
    Damped System
A proportionally damped 2-DOF system is defined by mass matrix M, stiffness matrix K, and a damping matrix C expressed as C = α M + β K + γ KM-1K. The damping ratios are specified as ζ1 = 0.1 and ζ2 = 0.3. To determine the coefficients α and β, one must derive two simultaneous equations based on the relationships between the damping coefficients and the system's natural frequencies. It is noted that assuming γ = 0 simplifies the problem, as three unknown coefficients cannot be uniquely determined from only two conditions.
  • Understanding of 2-DOF dynamic systems
  • Familiarity with Rayleigh damping concepts
  • Knowledge of mass and stiffness matrices in mechanical systems
  • Proficiency in solving simultaneous equations
  • Study the derivation of damping coefficients in multi-degree-of-freedom systems
  • Learn about Rayleigh damping and its applications in structural dynamics
  • Explore the implications of damping ratios on system behavior
  • Investigate numerical methods for solving dynamic equations in mechanical systems
Mechanical engineers, structural analysts, and students studying dynamic systems who are focused on understanding and applying concepts of damping in multi-degree-of-freedom systems.
toaster89
A proportionally damped 2-DOF system has mass and stiffness matrix M and K. We also know that the system has damping ratio ζ1 = 0.1 and 2 = 0.3. The damping matrix is written as
Try to find the coefficients
Mx"+Cx'+kx=0
CM^-1K=KM^-1C
Mx"(t)+(αM+βK+γKM^-1K)x'(t)+kx(t)=0
x(t)=M-.5 x q and multiply by M-.5
q"(t) + (αI+βK+γM-.5 M-.5 KM-1K)q'(t)+Kq(t)=0
q"(t)+(αI+βK+γ2M-.5K)q't+Kq(t)=0
So far this is all i got and now i am stuck
any tips?
I'm trying to figure out the same problem, were you ever able to figure it out?
I don't know why you have 3 unknown coefficients in your expression for C when you only have two requirements to meet. That will not give you a unique answer. You might as well assume γ = 0.
C = α M gives a damping ratio proportional to 1/ω.
C = β K gives a damping ratio proportional to ω.
The mode shapes with Rayleigh damping are the same as with no damping.
(Those results should be in your textbook or course notes).
So you get two simultaneous equations to find α and β in terms of ζ1 and ζ2.
I have encountered a vertically oriented hydraulic cylinder that is designed to actuate and slice heavy cabling into sections with a blade. The cylinder is quite small (around 1.5 inches in diameter) and has an equally small stroke. The cylinder is single acting (i.e. it is pressurized from the bottom, and vented to atmosphere with a spring return, roughly 200lbs of force on the spring). The system operates at roughly 2500 psi. Interestingly, the cylinder has a pin that passes through its...
  • · Replies 19 ·
