Protecting Your Computer from Solar Storms - Is a Faraday Cage Enough?
Icositetraedro
How did you find PF?: Via Google search
From what I understand in scientific publications, if there is a strong solar storm directed towards the Earth, the effects would be such that any electronic equipment would suffer irreparable damage. I ask, if I put my computer inside a Faraday cage would it also be damaged?
Welcome to PF!
While Faraday cages can block some level of transmission, it’s always possible that an incredibly strong transmission can reach the gear inside the cage.
https://en.wikipedia.org/wiki/Faraday_cage
Notice that what the cage can block is dependent on the mesh spacing and the wavelength of the transmission ie slow changing transmissions ie large wavelength can get through.
Hello and :welcome: !
What for? Our power supplies will be down for years if the storm is heavy enough. They estimate that it will take up to ten years to replace all the insulators in transformation facilities.
Couple that solar storm report with the UN report on climate last week plus new COVID variants more deadly than Delta, plus all the volcanoes and earthquakes, and I guess the end of the world is nigh.
Man in a trench coat holding a sandwich-board sign reading 'THE END OF THE WORLD IS NIGH', with 'NIGH' crossed out and 'NOW' written beside it in white marker, in front of a wooden fence and green shrubs.
@fresh_42 is right. If the world has no electricity, there's not much use for computers.
Welcome to PF. :smile:
In addition to using a shielded room to protect equipment from the strong ElectroMagnetic Interference (EMI), you need to put filters and transient suppression devices on the cables that connect the equipment inside the room to power and data cables outside of the room. It does little good to use a shielded room if the cables are not filtered and protected too.
Cover of an ETS-Lindgren brochure titled Series 81/71 Shielding Systems, showing a large steel-walled shielded room with a door, over a faint blueprint background.
https://www.yumpu.com/en/document/view/19537459/series-81-71-shielding-systems-ets-lindgren
They make good conversation pieces, door stops and coasters.
  • Haha
