Prove 7 > (2^0.5 + 5^0.5 + 11^0.5)
  • Context: MHB
  • Thread starter Thread starter Albert1
The discussion revolves around proving the inequality \(7 > (\sqrt{2} + \sqrt{5} + \sqrt{11})\). Participants explore various mathematical approaches and reasoning methods to establish this inequality without the use of calculators or computers.
  • One participant presents a detailed algebraic manipulation to show \(7 > \sqrt{2} + \sqrt{5} + \sqrt{11}\) through a series of inequalities and squaring steps.
  • Another participant shares a clever method involving rewriting \(7\) as a sum of square roots, suggesting that this approach could demonstrate the inequality without direct calculation of square roots.
  • There is a discussion about the validity of the proof methods, particularly regarding the order of operations and the implications of using square roots in inequalities.
  • Participants express concerns about the logic of moving from bottom to top in proofs, debating whether this approach is valid and how it affects the direction of inequalities.
  • One participant clarifies the rules regarding the application of monotonically increasing and decreasing functions in the context of inequalities, emphasizing the importance of ensuring both sides of an inequality are positive when squaring.
  • Another participant points out that assuming the conclusion in a top-to-bottom approach could lead to circular reasoning, which is not valid in proofs.
Participants do not reach a consensus on the best method for proving the inequality. There are competing views on the validity of different proof strategies and the implications of manipulating inequalities.
Participants express uncertainty about the implications of their proof methods, particularly regarding the treatment of square roots and the order of operations in inequalities. There are unresolved questions about the assumptions made in the proofs presented.
Albert1
originated from checkittwice
please prove :
$7>(\sqrt 2+\sqrt 5 +\sqrt {11}\, )$
note : you can not use calculator or computer
Mathematics news on Phys.org
Re: prove 7>(2^0.5+5^0.5+11^0.5)
$$7 > \sqrt{2} + \sqrt{5} + \sqrt{11}$$
$$7 - \sqrt{11} > \sqrt{2} + \sqrt{5}$$
$$ \left (7 - \sqrt{11} \right )^2 > \left ( \sqrt{2} + \sqrt{5} \right )^2$$
$$60 - 14 \sqrt{11} > 7 + 2 \sqrt{10}$$
$$53 > 2 \sqrt{10} + 14 \sqrt{11}$$
$$53 - 14 \sqrt{11} > 2 \sqrt{10}$$
$$\left ( 53 - 14 \sqrt{11} \right )^2 > \left ( 2 \sqrt{10} \right )^2$$
$$4965 - 1484 \sqrt{11} > 4 \cdot 10$$
$$4925 > 1484 \sqrt{11}$$
$$4925^2 > 1484^2 \cdot 11$$
$$24255625 > 24224816$$
Very ugly, but at least it does not calculate any square root. I remember proving this more elegantly before... (Worried)
A very clever method posted at MMF, which I wanted to share here, is as follows:
$\displaystyle 7=\frac{17}{12}+\frac{9}{4}+\frac{10}{3}=\sqrt{ \frac{289}{144}}+\sqrt{\frac{81}{16}}+\sqrt{\frac{100}{9}}=\sqrt{2+\frac{1}{144}}+\sqrt{5+\frac{1}{16}}+\sqrt{11+\frac{1}{9}}>\sqrt{2}+\sqrt{5}+\sqrt{11}$
Actually, your logic has to start at the bottom and go to the top. In that direction, you are taking square roots.
How do you mean? I never actually calculated a square root, just manipulating them as $\sqrt{a} \sqrt{b} = \sqrt{ab}$ and similar rules.
Besides, wouldn't going backwards require you to solve $a^2 = 24255625$?
EDIT: ah, I see what you mean. But why isn't it valid top-to-bottom? I thought every step was an equivalence?
@Bacterius:
In thinking about your logic going from bottom to top, I discovered that it's not the square roots that are the "problem". The rule for inequalities is this: any time you take a monotonically increasing function and apply it to both sides of an inequality, you get to preserve the direction of the inequality. Any time you take a monotonically decreasing function and apply it to both sides of an inequality, you need to reverse the direction of the inequality. If the function is not monotonically increasing or decreasing, then watch out!
The square root function is monotonically increasing on its domain. So, no problem. The square function, on the other hand, is monotonically decreasing for negative inputs, and monotonically increasing for positive outputs. So any time you square something in an inequality proof, you need to check that both sides are positive (keep the direction of the inequality) or that they are both negative (reverse the inequality).
Now, if I start at the bottom of your proof and work my way up, I notice that there are only three different kinds of steps in your proof: rewrites, square roots, and "shuffles" (shifting things from one side to the other by using addition or subtraction, which never requires an inequality reversal). You never square anything. So I think your proof is fine.
I think in my mind I was wondering about square roots, because if you start from $x^{2}>y^{2}$, you could either have $x>y$ or $-x<-y$. But in your proof, there are no variables anywhere, it's all numbers. And if you start from the bottom and work your way up, you can see that you take the positive square root a number of times, which is perfectly fine.
Sorry to invade this thread (Tmi), but I'd like to answer Bacterius' question:
If you go top-to-bottom you're essentially assuming what you want to prove, arriving at some true statement and saying "therefore, what we assumed is right", and you can't do that. They may be equivalent, but the order which you show they are equivalent is important.
Again, sorry for the intrusion. (Tmi)
Cheers.
  • · Replies 81 ·
10K
  • · Replies 24 ·
