MHB Prove a_0+a_1+…+a_2016>3^(2017)−1
  • Thread starter Thread starter lfdahl
The polynomial P(x) has 2017 real roots, denoted as λ_k, and the polynomial P(Q(x)) has no real roots, where Q(x) = (1/4)x^2 + x - 1. Since the minimum value of Q(x) is -2, all roots λ_k must be less than -2. Evaluating P(1) leads to the conclusion that P(1) > 3^2017, which implies that the sum of the coefficients a_0 + a_1 + ... + a_{2016} is greater than 3^2017 - 1. This establishes the required inequality.
lfdahl
MHB
Suppose, that the polynomial $P(x) = x^{2017}+a_{2016}x^{2016}+ a_{2015}x^{2015}+ … + a_1x + a_0$ has $2017$ real roots,
while the polynomial $P(Q(x))$, where $Q(x) = \frac{1}{4}x^2+x-1$, has no real root.
Prove, that $a_0 + a_1 + … + a_{2016} > 3^{2017}-1.$
Mathematics news on Phys.org
[sp]If $\lambda_1,\,\lambda_2,\ldots,\lambda_{2017}$ are the real roots of $P(x)$ then $P(x) = (x - \lambda_1)(x - \lambda_2)\cdots (x - \lambda_{2017}).$
If there is a real number $x$ such that $Q(x) = \lambda_k$ for some $k$, then $x$ would be a real root of $P(Q(x))$. Therefore none of the roots $\lambda_k$ can be in the range of the polynomial $Q(x)$.
The minimum value of $Q(x)$ is $Q(-2) = -2$, so the range of $Q(x)$ is $[-2,\infty)$. Therefore $\lambda_k < -2$ for all $k$. It follows that $$\begin{aligned}P(1) &= (1 - \lambda_1)(1 - \lambda_2)\cdots (1 - \lambda_{2017}) \\ &> (1 - (-2))(1 - (-2))\cdots (1 - (-2)) = 3^{2017}.\end{aligned}$$ But $P(1) = 1+a_{2016} + a_{2015} + \ldots + a_1 + a_0$. Thus $a_0 + a_1 + \ldots + a_{2016} > 3^{2017}-1.$
[/sp]
[/sp]
The ink has hardly dried, before you came up with this excellent solution, Opalg!
Thankyou very much for your participation!(Clapping)
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
