Prove by induction that sum of cubes equals sum squared
  • Thread starter Thread starter Jimmy84
    Induction
17 replies · 4K views
Jimmy84
Prove using induction
1.) 1^3 + 2^3 + 3^3 + ... + n^3 = (1 + 2 + 3 + ... + n)^2
2.) 1^3 + 2^3 + ... + (n-1)^3 < (n^4)/4 < 1^3 + 2^3 + ... + n^2
I don't have a clue about how to start to do the problems can anyone help me ?
Thanks.
When you don't know what to do, start by writing down what you know.
How to prove a theorem by induction.
1) Prove a case (usually n=1 or something).
2) Prove that if your theorem is true for some value of n, it is true for n+1.
So start by proving the statements for n=1, or maybe n=3 since the second statement involves n-1.
Then prove that IF it's true for n, it's true for n+1.
do you understand the inductive process?
First show its true for a particular n, usually n=1
Then asumes it true for n, see if you can show it is then true for n+1 based on that fact
Then it is true for all n greater than 1 (or whatever value you started at)
I've done the first question before, it isn't that easy (unless you look it up what I'm going to post below).
It's related to these numbers (n^3) : (cubic numbers)
1^2 = 1
2^3 = 8 = 3 + 5
3^3 = 7 + 8 + 9
4^3 = 11 + 13 + 15 + 17
.. et c
generalize and these results and prove the generalization, then you may use it for 1^3 + ... + n^3 = (1+2+..+n)^2.
this may help you: 1 + 3 + ... + 2(n) - 1 = n^2
good luck
as i think wisvuze is implying you may need to use a few inductions (rather than just the single inductive step) to get the result - have a try & we'll step through it
Im familiar with having a single inductive step however the ones that use more step are more complicated.
I couldn't find a generalization for
1^2 = 1
2^3 = 8 = 3 + 5
3^3 = 7 + 8 + 9
There is no generalization I could find for 1, 8, 24, and 56. what can I do about it?
In problem one
would then be
1^3 + 2^3 + 3^3 + ... + (n+1)^3 = (1 + 2 + 3 + ... + n+1)^2
but I can't go further from that . because I can't take just n+1 as one single variable in order to make sense I need the other sum of real numbers of the equation.
ok so examining n+1 case gives (note I've just added tex tags around you formula - try clicking on equation to see what i mean):
[tex]1^3 + 2^3 + 3^3 + ... + n^3 + (n+1)^3 = (1 + 2 + 3 + ... +n+ (n+1))^2[/tex]
exapanding some of the square
[tex](1^3 + 2^3 + 3^3 + ... + n^3) + (n+1)^3 <br /> = ((1 + 2 + 3 + ... +n) +(n+1))^2[/tex]
[tex](1^3 + 2^3 + 3^3 + ... + n^3) + (n+1)^3 <br /> = (1 + 2 + 3 + ... +n)^2 +2(n+1)(1 + 2 + 3 + ... +n) + (n+1)^2[/tex]
now if we assume the orginal hypothesis is true for n, it reduces to:
[tex](n+1)^3 = 2(n+1)(1 + 2 + 3 + ... +n) + (n+1)^2[/tex]
removing a factor of (n+1)
[tex](n+1)^2 = 2(1 + 2 + 3 + ... +n) + (n+1)[/tex]
if you can prove the above relation you're pretty much there - so you could try induction again (i haven't done it, but looks like a reasonable way to attempt the problem)
This last relation follows directly from the formula for summing the first n integers.
cool, then induction should work for that if you can't just assume it & then you just need to show the hypthesis is true for some starting n value
Sorry I have been very busy all this time it has been quite hard to find a way to solve this problem.
You told me to prove
but I am not sure about how to do that.
I tried [tex](n+2)^2 = 2(1 + 2 + 3 + ... +n+1) + (n+2)[/tex]
then [tex]n^2 +4n +4 = 2 (1+2+3+... +n+1) + (n+2)[/tex]
But I am totally lost here I would appreciate some help.
Start by finding a closed formula for:
[tex]\sum_{k=1}^n k = (1 + 2 + 3 + ... + (n-1) + n)[/tex]
What do you mean by a closed formula?
Something that's only in terms of n, and doesn't involve a summation.
1^2 = 1
2^3 = 8 = 3 + 5
3^3 = 7 + 8 + 9
Notice: 1^2 = 1, 2^3 = 3 + 5 .. et c nth term is the sum of n odd numbers, starting from where n-1's odd terms left off
This question was presented this way in Donald Knuth's popular book "The Art of Computer Programming".
[tex]n(n+1)/2[/tex]
What use I can give to that in order to prove the original equation?
Now you have an expression you can fill in on the right side of that equation, right?
ok [tex](n+1)^2 = n(n+1) + (n+1)[/tex]
that is [tex]n^2+2n+1 = n^2+2n+1[/tex]
How can I start with the second problem?
2.) [tex]1^3 + 2^3 + ... + (n-1)^3 < (n^4)/4[/tex]
Now use the result you just proved to substitute into the left and right sides of the second inequality.
