Prove that gcd(n, n+3) = 1 when n is not divisible by 3
  • Thread starter Thread starter knowLittle
    Proof
12 replies · 3K views
knowLittle
Let ##n \in \mathbb{Z} , n \not | 3##. Prove that ##gcd( n , n +3 ) =1 ##
If n is not divisible by 3, then
n = 3k+1 or n =3k+2 , ## k \in \mathbb{Z} ##
What is a feasible approach? Can I do this?
For first case,
## gcd(3k+1, 3k+4 ) = 1 \\ \exists s,t \in \mathbb{Z} \\ 1 =(3k+1)s + (3k+4)t ##
I would just use the definition. Assume that there is an integer ##d## that divides both ##n## and ##n+3##, then...
Thanks.
You mean state Euclid's lemma?
Let ## a,b,c \in \mathbb{Z} \wedge a \not = 0 ## . If ## a|bc \wedge gcd(a,b) =1 , ##then ## a|c ##
## n | (n+3)c , c \in \mathbb{Z} \\ n| c##?
I don't see how this is applicable here. Just use the definitions.
## d| n+3 \\ d|n \\ n =dk \wedge n +3 = dp, p,k \in \mathbb{Z} \\ 3=d(p-k) ## Since p-k is an integer, d|3 ?
I don't get where is the connection of ##d## with ##n## not divisible by 3.
Ok, so you found that ##d## divides ##3##. Can you then list all the possible values that ##d## can be?
Since 3 is prime d can be 1 or 3.
So you need to prove that ##d=3## can't happen.
So,
## d=3 \\ n =3k \\ n+3 =3p \\ gcd(n, n+3 ) =1 \\ nh + (n+3)x =1, h,x \in \mathbb{Z} \\ 3(kh+px) =1, kh+px \in \mathbb{Z} ##
Then, 3|1; however, 1 =3y is impossible, since y must be integer.
So, necessarily d =1 only.
I still don't see the connection. Are we assuming that ## d \equiv n##?
knowLittle said:
So,
## d=3 \\ n =3k \\ n+3 =3p \\ gcd(n, n+3 ) =1 \\ nh + (n+3)x =1, h,x \in \mathbb{Z} \\ 3(kh+px) =1, kh+px \in \mathbb{Z} ##Then, 3|1; however, 1 =3y is impossible, since y must be integer.
Again, you're overthinking the problem.
If a number divides two distinct numbers, then it also divides their difference. Hence d divides 3. Since 3 is prime, that means d can be 3 or 1.
Since d divides n, and d = 3, does 3 divide n? Does that violate any of the stipulations of the question? What does that leave you with as a possible value of d?
So, d | n
d =3
does 3 |n ?
Well, the stipulations say that ##n## is not divisible by 3. ## n\not | 3 ##
Sorry, but again I am lost.
## (n = 3k )\not = (3 \not = np), k,p \in \mathbb{Z} ##
knowLittle said:
So, d | n
d =3
does 3 |n ?
You KNOW that ##d \mid n.## (Fact 1)
You KNOW that ##d \mid 3.## (Fact 2)
You KNOW that ##3 \nmid n.## (Fact 3)
Fact 2 implies that ##d=1## (possibility 1) or ##d=3## (possibility 2) because 3 is prime.
IF possibility 2 were true, THEN by Fact 1, ##3 \mid n##. But this cannot be so because it would conflict with Fact 3. Therefore possibility 2 is rejected.
That leaves only possibility 1, i.e. ##d=1##. The only possible common divisor for ##n## and ##n+3## where ##3 \nmid n## is 1. Therefore, this is also the greatest common divisor.
By the way, you're using the non-divisibility notation wrongly. If you want to state that n is not divisible by 3, it should be ##3 \nmid n## (read as '3 does not divide n', or '3 is not a divisor of n').
Thank you very much, Curious.
BTW, that cat in your pic looks happy :>
