Prove det(A+I)=0 when Matrix A is Nilpotent
  • Context: Graduate
  • Thread starter Thread starter lukaszh
    Determinant
The discussion revolves around proving the determinant of the matrix \( A + I \) when \( A \) is a nilpotent matrix. Participants explore the implications of nilpotency on eigenvalues and determinants, with a focus on the relationship between the eigenvalues of \( A \) and \( A + I \).
  • One participant states that if \( A \) is nilpotent, then \( A^k = 0 \) and asks to prove \( \text{det}(A + I) = 0 \).
  • Another participant counters that the claim is false by providing the example of \( A = 0 \), where \( \text{det}(0 + I) \neq 0 \).
  • A different participant argues that since \( \text{det}(A^k) = \text{det}(A)^k \), it follows that \( \text{det}(A) = 0 \) and concludes that 0 is an eigenvalue of \( A \), suggesting that \( \text{det}(A + I) = 1 \) instead.
  • Subsequent posts clarify that the original question was misstated, confirming the need to prove \( \text{det}(A + I) = 1 \).
  • One participant discusses the eigenvalues of \( A + I \) and how they relate to the eigenvalues of \( A \), asserting that if \( A^k = 0 \), then all eigenvalues of \( A \) must be zero.
There is disagreement regarding the initial claim about \( \text{det}(A + I) \). Some participants propose that it should equal 1 instead of 0. The discussion remains unresolved on the exact proof and implications of nilpotency on the determinant.
Participants express uncertainty about how to utilize the fact that \( A^k = 0 \) in their arguments. There are also varying interpretations of the implications of nilpotency on eigenvalues and determinants.
lukaszh
Hello,
I don't want how to prove: Matrix A is nilpotent, so A^k=0. Prove that det(A+I)=0.
Thank you so much :-)
What you state is trivially false - take A=0, that is nilpotent, and det(0+I) is not zero.
In fact, det(A^k) = det(A)^k, so det(A) must be zero. Alternatively, A^k = 0, so A cannot be injective, so det(A) = 0.
By the way, this shows that 0 is an eigenvalue of A. Something stronger is true: 0 is the ONLY eigenvalue of A.
I think lukaszh's problem statement should be: prove that det(A+I) = 1.
I'm so sorry, because I've made a mistake. Prove that det(A+I)=1. Thank you again for your reactions.
First, find all the eigenvalues of A+I. Then, use what you know about how to calculate the determinant of a linear map given its eigenvalues.
Hello,
so, I know that
[tex]A=S\Lambda S^{-1}[/tex]
Eigenvalues of A are [tex]\{\lambda_1,\lambda_2,\cdots,\lambda_n\}[/tex] for [tex]n\times n[/tex] matrix. If I add to both sides identity, then
[tex]A+I=S\Lambda S^{-1}+I=S\Lambda S^{-1}+SS^{-1}=S(\Lambda+I)S^{-1}[/tex]
Its determinant is
[tex]\mathrm{det}(A+I)=\mathrm{det}S(\Lambda+I)S^{-1}=\mathrm{det}(\Lambda+I)=\prod_{j=1}^{n}(\lambda_j+1)[/tex]
I don't know, how to utilize fact [tex]A^k=0[/tex] :-(
lukaszh said:
Hello,
so, I know that
Its determinant is
[tex]\lambda[/tex] is an eigenvalue of A + I if and only if
[tex](A + I)x = \lambda x[/tex]
for some nonzero vector x. This is true if and only if
[tex]Ax = (\lambda - 1)x[/tex]
which is true if and only if [tex]\lambda - 1[/tex] is an eigenvalue of A.
I claim that [tex]A^k = 0[/tex] implies that all of the eigenvalues of A are zero. If you can prove this claim then it implies the result you want.
Beautiful, thank you.
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 34 ·
