Prove RS is parallel to KL using vector method
20 replies · 3K views
Richie Smash
Hi I have attached an image which shows OK and OM which are position vectors such that OK=k and OM =m
R is the mid point of OK and S is a point on OM such that (vec) OS = 1/3 OM
L is the midpoint of RM, using a vector method, prove RS is parallel to KL.
SO the questions asked me to find these vectors
MK=k-m
RM= m-k/2
KS= m/3-K
RS= m/3-k/2
So now tht I've found these vectors,
I would think that I need to prove that KL and RS are multiples of one another to show they are parallel.
First I found the coordinates of L which is the midpoint of RM
L= (m-k/2)/2= m/2-k/4
So now that I know L... I find KL which would be : -k+(m/2-k)=m/2-2k
SO I know KL, and I know RS which is : m/3-k/2
But they don't seem to be multiples of each other... can anyone help me?
on Phys.org
You are treating the vectors as scalars, so your length calculations are incorrect. You need to consider the angles between the vectors and use the law of sines and law of cosines to get distances MK, RM, etc. Or better yet, use trigonometry to get the x- and y-coordinates of each point. Then you can use the Pythagorean theorem to get the distances.
Hey tnich, I don't doubt that what youre saying isn't correct, not at all, but I don't think that this level I'm doing requires that, as they would usually give angles it it was required, I'm pretty sure there has to be another way.
Good luck with that.
Oh yes it should be -k/4
You are on the right track but your notation is awful.
MK=k-m
RM= m-k/2
KS= m/3-K
RS= m/3-k/2
L= (m-k/2)/2= m/2-k
Check your arithmetic right there. Should get m/2 - k/4.
What... do I do now?
In order to talk about this sensibly I am including a better picture:
In this picture I have labeled points with lower case and vectors with upper case. So:
##\vec K = ok,~ \vec R = or = \frac 1 2 \vec K,~\vec M = om,~ \vec S = os = \frac 1 3 \vec M## so ##rs=\vec S -\vec R
=\frac 1 3 \vec M - \frac 1 2 \vec K##, which you have correct above.
Also ##\vec B = \frac 1 2 rm = \frac 1 2(\vec M - \vec R) ## to get you going. Express that in terms of ##\vec M##
and ##\vec K##, then get ##kl## in terms of them too. Show us how that goes.
I believe that B would be M/2 -K/2
But hmm since RS is M/3-K/2
KL must be M/4+2K/8
This is quite confusing, but to express B=1/2(M-R)
R is the same as K/2
So in that sense B would be M/2-K/2 yes?
No. Same kind of algebra mistake you had before.
What mistake might that be? having the new diagram clears up the position of the lines for me but I still find it a bit difficult
Oh yes I see, B would be M/2-K/4
Ummm NO sir, that would mean then that, KL, or in other words KB is, : -K/2 +M/2-K/4
So in other words that would be -3/4K +M/2 is KL
Well at this point I fail to see how RS or Kl could be a multiple of one another because if RS = M/3-K/2 then I just don't see the correlation unless I use common fractions then RS would be 4/12M-6/12K
and KL would be 6/12 M -9/12K then I suppose that KL is 1.5RS?
This does seem correct...
Yes, it does seem correct. I have a few parting comments though. First, there is no need for decimals in this problem. You should be able to show directly that ##kl = \frac 3 2 rs##. Also note that you are confusing points with vectors when you write KL when you should write ##kl##. Finally, you are also abusing mathematics notation when you write something like 4/12M when you mean (4/12)M. Hopefully with more practice you will get better at it.
