Prove sum of two primes is even
  • Thread starter Thread starter cragar
    even Primes Sum
The discussion centers on proving that the sum of two prime numbers greater than 2 is even. Participants agree that since all prime numbers larger than 2 are odd, the sum of two odd numbers must be even. A clear proof is suggested, using the representation of odd integers as 2a + 1 and 2b + 1, leading to the conclusion that their sum is divisible by 2. The importance of presenting the argument in an organized manner is emphasized, with suggestions for streamlining the proof. Overall, the conversation highlights the mathematical reasoning behind the assertion and the need for clarity in proofs.
cragar
Prove: If a and b are prime numbers larger than 2, then a + b is even.
Can i just say that prime numbers larger than 2 are odd and then prove that the sum of 2 odd numbers is even. And can i say that prime numbers larger than 2 are odd because prime numbers only have factors of 1 and themselves and if 2 was a factor then it wouldn't be prime.
That's what I would do, but then I'm an engineer, not a mathematician
Hi cragar! :smile:
What you say is certainly correct. But I don't know how rigourous your argument needs to be. For example, you still need to show that the sum of two odd numbers is even.
I think the trick is here to write it down in a clear, organized way.
ok so would I show that the sum of 2 odd integers is even by
proof:
Let x and y be odd integers and there exists integers a and b such that
x=2a+1 and y=2b+1 .
then x+y=(2a+1)+(2b+1)
then x+y=2a+2b+2
x+y=2(a+b+1)
since x+y is divisible by 2 therefore it is even.
Looks good! :smile:
sweet , thanks for your help.
Ha ha, you I am a physics major learning to write proofs. I can't tell you how many times my physics profs cut corners on the math that would make a mathematician cringe.
You should try an engineering class, :P. It makes ME cringe.
proof:
x=2a+1 and y=2b+1 .
then x+y=2a+2b+2
x+y=2(a+b+1)
Nothing wrong with what you did, but you can economize a bit like so:
then x+y=(2a+1)+(2b+1) = 2a+2b+2 = 2(a+b+1)
Since x+y is divisible by 2, therefore it is even.
  • · Replies 16 ·
