Prove that the inverse of an integer matrix is also an integer matrix
The discussion centers on proving that the inverse of an invertible integer matrix A is also an integer matrix if the determinant of A (det A) equals 1 or -1. Participants confirm that if det A = 1 or -1, then the adjoint of A is an integer matrix, leading to the conclusion that A-inverse is also an integer matrix. Conversely, if A-inverse is an integer matrix, then det A must be either 1 or -1, as established through properties of determinants and the relationship between A and its inverse.
  • Understanding of integer matrices and their properties
  • Familiarity with determinants and their calculations
  • Knowledge of adjoint matrices and their role in finding inverses
  • Basic concepts of linear algebra, particularly matrix operations
  • Study the properties of determinants in detail, focusing on integer matrices
  • Learn about adjoint matrices and their computation
  • Explore the concept of matrix inverses and their derivation
  • Investigate the application of induction in proving matrix properties
Mathematics students, particularly those studying linear algebra, as well as educators and anyone interested in the properties of integer matrices and determinants.
bigevil
A is an invertible integer matrix. Prove that if det A = 1 or det A = -1, then the inverse of A is also an integer matrix.
Also prove the reverse, if A-inverse is an integer matrix then its determinant is 1 or -1.
I'm not too sure how to start here. My first instinct is to work backwards from some properties of determinants that I know of.
det A-inv = det A
det [A(A-inv)] = det(A)det(A-inv) = det(A) det(A) = det I = 1, so det A = 1 or -1.
Same can be proven for A-inv, det (A-inv) det (A-inv) = det I = 1, so det A-inv = 1 or -1.
I'm not so sure how to approach this from here. Sorry if this is a stupid question, I am studying on my own, not in college and not many other resources to turn to.
One method of finding the inverse of a matrix is to set a-1ij[/b]= Aji/d where Aji is the determinant of the "minor" (matrix you get by removing jth row and ith column) and d is the determinant of A. If A is \pm 1, what does that tell you?
Halls, I'm not sure if I'm familiar with that equation. Do you mean the adjoint matrix of A, ie, A-1 = Adj (A) / det A? Also not very sure about your question, what do you mean by A is +1 or -1?, the determinant?
If det A = 1 or -1, then the adjoint = inverse.
I have thought of something, not sure if this is the track you're pushing me along:
A det A = I = A A-1. Given A is an integer matrix, and already given that det A is an integer, then A-1 is also an integer matrix. Does that fit together right?
Yes, Hall's is talking about Adj(A). It's the transposed matrix of cofactors. If A is integer, then Adj(A) is definitely integer. For the second part, det(I)=det(A)*det(A^(-1)). If A and A^(-1) are integer matrices, then what about det(A) and det(A^(-1))? det(I)=1. Hence?
Ok, Dick:
If A and A-inverse are integer matrices then det A and det (A-inverse) are integers because of the Laplace expansion. det (I) = 1, so det (A A-inv) =1
det (A-inv) det (A-inv) = 1, and since both are equal, det (A-inv) must be 1 or -1.
Is this the right reasoning? Thanx Dick.
Indeed, the question itself provides the answer. When you say, integer, it means if you have f as a function of integers, then it can be easily manipulated into Drichilet functions and/or Dirac-Delta Functions. And, from here, you can use a lot of identities or transforms to achieve what is desired. Another method is to use induction. Another is to make a 2x2 matrix, where a ij element of I. Then find its inverse. And then prove every element of A inverse, is also an integer. Quite tedious, but has some charming results in the end.
bigevil said:
Ok, Dick:
No. Something seems to be evading you. There is NO reason why det(A-inv)*det(A-inv)=1. What you have is det(A)*det(A-inv)=1. det(A) and det(A-inv) are both integers. How many ways are there to multiply two integers and get 1?
Oh... sorry Dick I got it mixed up, was doing a question on determinant of transposes before this.
det A = det (A-inv) = 1 or
det A = det A(-inv) = -1, hence. Thanks Dick...
Madhawk, I'm not much of a mathematician...
  • · Replies 25 ·
  • · Replies 20 ·
15K
  • · Replies 18 ·
