Prove that x^n-y^n is divisible by x-y
  • Thread starter Thread starter mxam
The discussion focuses on proving that \(x^n - y^n\) is divisible by \(x - y\) using mathematical induction. Participants emphasize the importance of establishing a base case (n=1), assuming the statement holds for \(n=k\), and then proving it for \(n=k+1\). Key expressions such as \(x^{k+1} - y^{k+1} = x(x^k) - y(y^k)\) are highlighted, along with the necessity of using polynomial long division and the geometric series formula for clarity in the proof process.
  • Understanding of mathematical induction
  • Familiarity with polynomial expressions and their factors
  • Knowledge of the geometric series formula
  • Basic algebraic manipulation skills
  • Study the principles of mathematical induction in detail
  • Learn about polynomial long division techniques
  • Explore the geometric series and its applications in proofs
  • Practice proving divisibility of polynomials through examples
Students of algebra, educators teaching mathematical proofs, and anyone interested in enhancing their understanding of polynomial divisibility and induction methods.
mxam
I don't know how to prove by mathematical induction that x^n-y^n is divisible by x-y . . . Can you show me step by step? . . .Greetings!
Sorry, but the rules of PF state clearly that you must make an attempt at solution.
As to proofs by induction, start with n = 1, 2, 3, etc. and see if the resulting polynomial is divisible by x-y. If you don't run into a contradiction along the line, try making a general statement for any integer n.
Code:
[itex]((x^n-y^n)/x-y)=>\frac {x^1-y^1} {x-y}=>\frac {x-y} {x-y} OK [/itex]
Now, n= k
Code:
[itex]x^k-y^k = m(x-y) ; [/itex] where m is a positive integer.
Now, my question is n=k+1 where,
Code:
[itex]x^k+1+-y^k+1= ?[/itex]
I don´t understand the next step, i saw some explanations on internet but i don't understand ! Help me please. :s
When you say "Divisible by" x-y, that means that (x-y) is a polynomial factor, not exactly that ##x^k - y^k = m(x-y)## where m is a positive integer, but that m is a polynomial.
Note that ##x^2-y^2= (x-y)(x+y)## and ##(x^3 - y^3) = (x-y)(x^2 +xy +y^2) ##.
mxam said:
Code:
Now, n= k
Code:
Code:
Your Latex skills have let you down here. You need to use curly brackets { } to collect the right terms in the exponents.
Code:
[itex]x^{k+1}-y^{k+1}= ?[/itex]
Do you know the expression for the sum of a geometric sequence ? See http://www.regentsprep.org/regents/math/algtrig/atp2/geoseq.htm
ehild
So noted, and dealt with.
I think that using the formula for the sum of a geometric sequence is the simplest way to do this but would NOT be a proof by induction.
mxam, write x^{k+ 1}- y^{k+1} as x(x^k)- y(y^k)= x(x^k)- (y(x^k)- y(x^k))- y(y^k)= x^k(x- y)+ y(x^k- y^k)
Are you allowed to use polynomial long division?
Thanks for your answers. I saw a "clear" solution online, let me show you:
mxam said:
Code:
Now, n= k
Code:
n=k+1
Code:
[itex]x^{k+1}-y^{k+1}[/itex]
Code:
[itex](x^1)(x^k)-(y^1)(y^k)[/itex]
Code:
[itex]x(x^k)-x(y^k)+x(y^k)-y(y^k)[/itex]
And later the solution. But I don't understand just 1 thing, why are using x(y^k)? . . . where the origin for it? . . .
I appreciated your time. This is a old homework of Algebra, but is exercise unresolved, and now, i want to know the real way to resolve it. . .
mxam said:
Code:
Now, n= k
Code:
n=k+1
Code:
Code:
Code:
There are three things you need to do in an induction proof:
1. Show that the statement is true for some starting value of n, typically, but not always, n = 1.
2. Assume that the statement is true for n = k. This is called the induction hypothesis.
3. Using the induction hypothesis of step 2, show that the statement is true for n = k + 1.
In your work shown above, you established step 1 by showing that x1 - y1 is divisible by x - y. For step 2, it was not clear that you were assuming that xk - yk is divisible by x - y. Also, you are throwing in a lot of symbols, such as => ("implies") that aren't appropriate here. You should be using = to connect expressions that have the same value.
You didn't finish things by working through step 3. Another poster in this thread has already mentioned that you can't write xk - yk as a constant m times (x - y). You could write this as xk - yk = m(x)(x - y), where m(x) is a polynomial of degree k - 1.
Finally, you don't need to wrap [ code ] tags around your [ itex ] tags.
mxam said:
Thanks for your answers. I saw a "clear" solution online, let me show you:...x(xk)−x(yk)+x(yk)−y(yk) And later the solution. But I don't understand just 1 thing, why are using x(yk)? . . . where the origin for it? . . .
It is always possible to add and subtract the same term to an expression. It is just a clever thing to do. You can arrange the expression so it is the sum of two terms, both divisible by x-y:
x(xk−yk)-yk(x-y).
ehild
x(xk−yk)-yk(x-y).
ehild
Thanks. . . .
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 69 ·
9K
