##f(x+y) =f(x) f(y)## and ##f(1)+f(2)=5## then find ##f(-1)=?##
49 replies · 6K views
Yes, it is.( cf. post #16).
The relation f(x+y)=f(x)f(y) does not limit b. Other additional conditions may confine b to real positive.
Reply
sorry for the confusing notation. I have chosen a vector subspace W of the reals containing π and such that every real has a unique expression as a sum a+b, where a is in the subspace Q spanned by the real number 1, and where b belongs got the subspace W. Then if x is any real number, we can write x = a+b (uniquely with a in Q and b in W), and then my function f takes x to e^a.π^b. In particular, an element x in Q goes to e^x, and an element x in W goes to π^x, i.e. for x in Q we have a =x and b =0, and for x in W we have a=0 and b = x.
This choice of W also gives a vector space isomorphism from R to the vector space Q+W defined as pairs (a,b) with a in Q and b in W, and I used that isomorphism to represent the real number x by the pair (a,b). I guess that was confusing. In that notation 3.14 was represented as (3.14, 0), and π was represented as (0, π).
The isomorphism takes Q+W-->R, by sending (a,b) in Q+W, to a+b in R. This definition of Q+W as a set of pairs, is called an "exterior" direct sum, and is usually written with a circle around the plus sign, but I can't do that. Some people write Q+W to mean the "interior" sum, meaning simply the subspace of R consisting of all sums a+b of elements a in Q and b in W. That would be the image of my map above Q+W-->R.
In general, if E,F are subspaces of a vector space V, then V is the direct sum of E and F if and only if either of these two things is true, (iff both are true):
1) Every vector x in V is expressible uniquely as a sum x =a+b, with a in E and b in F.
2) The map E+F-->V from the exterior direct sum E+F to V, taking (a,b) to a+b, is an isomorphism.
Reply
It seems about all one can say about a map f:R-->R that satisfies f(x+y) = f(x).f(y), is that (it is either identically zero or always positive, and if not zero, then) for all real x and all rational r, that f(rx) = [f(x)]^r. If f is also continuous, then it seems that f(xy) = [f(x)]^y for all real x,y, hence f(x) = f(1.x) = [f(1)]^x, for all real x. so then f(x) = b^x where b = f(1).
If f is not continuous then f(rx) = a^r, with a = f(x), when f is restricted to the one - dimensional Q-subspace Q.x, namely all rational multiples of x, but the choice of a can thus differ for different subspaces.
This restriction is not quite yet written as f(y) = b^y, but if x is any non- zero element of the subspace, hence a basis, then every element y of the subspace Q.x, can be uniquely written as y = rx for r rational, hence we may write y/x = r, and hence, if a = f(x), then f(y) = a^(y/x), for every y in Q.x. Hence the restriction has the form f(y) = a^(cy), where c = 1/x is a constant real number. And since a^(cy) = (a^c)^y, this means that f(y) does equal b^y, if we take b = a^(1/x) = f(x)^(1/x).
Thus if f satisfies the functional equation, then on any one dimensional Q-subspace of R, spanned say by x, we have f(y) = b^y, where b = [f(x)]^(1/x). But we can write R as a direct sum of an uncountable number of one- dimensional Q-subspaces, and it seems f can have a different b in every one of them. (I don't know if that forces the b's to be different in any two different one diml subspaces.)
Can we find pairwise function that satisfies problem conditions?
BTW would you show your answer of f(ー1) in order to avoid spoiler of homework?
##f(-1)=\frac{1+\sqrt{21}}{10}##
Reply
I don't know what you mean by a "pairwise" function. But I believe I have argued that the functional equation shows that the values of f are determined on all rationals once you know the value at a single non zero rational, but the value of f at a non rational point can still be essentially anything (positive).
Sorry that's typo, I mean piece wice function.
I suppose you mean by that a function with different definitions on two different subsets of the reals, and that is exactly what I defined in post 29, where I used the fact that every real number x can be written uniquely as a sum of two numbers, x = a+b, with rational a, and b chosen from a complementary Q- vector subspace W of the reals. Then I used the function e^x for rational x, and the function π^x for x in W. And for more general numbers of form x = a+b, with rational a, and b in W, you multiply them together getting f(x) = f(a+b) = f(a).f(b) = e^a.π^b.
mathwonk said:
since f(3.14) = e^(3.14), ..., f(3.14159) = e^(3.14159), etc..., but f(π) = π^π ≠ e^π.
You say f(##\pi##)=f(##\pi##-3+3)=##\pi##^(##\pi##-3)e^3 ?
So we should know your choice representing irrational numbers, e.g. ##\pi## among ##\pi##+1,##\pi##+2,…
by the axiom of choice, i.e. zorn's lemma, the Q-vector space R has a ( uncountable) Q- linear basis containing 1 and π. (just take a maximal Q-independent set of reals containing 1 and π.) Such a basis cannot be explicitly described, but it does contain 1 and π. So although I cannot tell you the value of f at most irrational points, e.g. I do not know the value of f(sqrt(2)), [unless I also require the basis to contain sqrt(2)], I can definitely tell it to you for numbers of form r+sπ, with r,s both rational. nonetheless the function f is well defined everywhere in terms of this basis. and I can define it on points of this basis almost at will, restricting the values to be positive.
As I simplified it, I took W to be the Q-subspace spanned by all basis elements except 1. Since I did not specify any other elements of W except (rational multiples of) π, I do not know the value of f at any elements except those of form r + sπ, for rational, r,s; but for those, f(r+sπ) = e^r.π^(sπ)
Now I know you are not saying about all irrational numbers but r+s##\pi##. f(e), f(##\sqrt{2}##) should be considered independently.
yes, that is why the example I gave is not so elementary. the fact that there exists a Q-basis of R at all, is quite abstract. to define an f such as I wanted, one cannot just divide the reals into rational and irrationals, one has to choose a Q-linear direct sum decomposition of R, and this cannot be done explicitly. so although my direct sum expression R = Q+W can be proved to exist, using zorn's lemma, hence the resulting f also is proven to exist, still it is not so easy to evaluate.
if I want to know the value of some such f also at sqrt(2), I note that 1, sqrt(2), and π are Q-linearly independent, hence I can find a decomposition R = Q+W where W contains both π and sqrt(2), and then my previous f will have value f(sqrt(2)) = π^(sqrt(2)).
or I could look at R as a direct sum R = Q+Q.π + V, where sqrt(2) belongs to V, and I can define f so that f(r) = e^r for rational r, and f(sπ) = π^(sπ) for rational multiples of π, and f(x) = 2^x for x in V, hence f(sqrt(2)) = 2^(sqrt(2)). this f will have f(7+π+3.sqrt(2)) = e^7.π^π.2^(3.sqrt(2)).
but now I don't know the value of f at sqrt(3).
[tex]f(x+y)=f(x)f(y) >0[/tex]
[tex]g(x):=\log f(x)[/tex]
[tex]g(x+y)=g(x)+g(y)[/tex]
[tex]g(0)=0,g(x)=-g(-x)[/tex]
It seems almost sure that
[tex]g(x)=cx[/tex]
Here we do not have to distinguish x is rational or irrational. Your discussion still works here ?
Interestingly, since you mention f(e), if we express R as a direct sum R = Q + Q.π + W, for some complementary Q-linear subspace W, and set f(x) = 2^x for x in Q+Qπ, but f(x) = 3^x for x in W, then we have no idea of the value of f(e)! I.e. we do not know how to express e as r + sπ + y, with y in W. In fact mathematicians apparently do not even know whether e+π is rational or not, so it is possible that here f(e) = 2^e.
In particular, it is not known whether 1, π and e are Q- independent, so we cannot prove there is a Q-basis of R that contains 1,π and e, hence we cannot prove the existence of a function f satisfying our functional equation and having arbitrary values at 1, π, and e, although we can do so for 1,π, and sqrt(2).
[I did not know this until tonight while searching for confirmation of the opposite (false) statement that I was about to make. ]
