Prove the definitions of Linear Transformations
13 replies · 3K views · last reply
jinksys
Show that 2.1.1 is equivalent to the totality of 2.1.2 and 2.1.3.
aTx + bTy = aT(x) + bT(y) = T(ax) + T(by) = T(ax + by) ?
It's really pretty easy. Just think clearly about what you have prove. But there is a really nasty typo in (2.1.3). It should read T(ax)=a*T(x). Is that what's confusing you?
I can 'get' that 2.1.1 follows from 2.1.2 and 2.1.3 and visa versa, but I'm not sure how to say it as a proof. I've never been good with proofs.
You aren't bothered by (2.1.3) saying T(ax)=a*x?? You should be. But if you aren't good at proofs, maybe you aren't. Change (2.1.3) to T(ax)=a*T(x). The first stage of the proof is show that (2.1.1) implies (2.1.2) and (2.1.3). That's pretty easy. I'll give you a hint for the first part. Put a=1 and b=1 into (2.1.1). What do you conclude?
I meant to say that I understood that T(ax)=aT(x), but only because I have other linear algebra books to help me get through this class.
If a=b=1,
T(ax +by) = T(1x + 1y) = T(1x) + T(1y) = 1T(x) + 1T(y) = T(x) + T(y)
Edit:
Now do I have to do a=a, b=0 to get:
T(ax + by) = T(ax) =aT(x) ?
If a=b=1,
Ok, that's good. So that shows (2.1.1) implies (2.1.2). Can you show it also implies (2.1.3)? The final step of the proof is showing (2.1.2) AND (2.1.3) imply (2.1.1).
I'm not sure if you saw my edit or not, so I'll just give it its own post.
To show 2.1.3, do I let a=a and b=0?
T(ax + by) where a=a, b=0:
T(ax + 0y) = T(ax) = aT(x).
Conversely with a=0, b=b:
T(0x + by) = T(by) = bT(y)
Sure, that shows T(ax)=a*T(x). So (2.1.1) implies (2.1.3). Now you just have to show (2.1.2) AND (2.1.3) imply (2.1.1). Try it. You are doing fine so far.
I'm stumped, I can see how you would prove that 2.1.1 implies 2.1.2 and that 2.1.1 implies 2.1.3, but I'm not sure how to combine them.
Umm. You want to show T(ax+by)=aT(x)+bT(y), right? (2.1.2) says T of the sum of two vectors is T(first vector)+T(second vector), yes? Are ax and by vectors you could apply (2.1.2) to?
If you let s = ax and t = by,
then T(s + t) = T(s) + T(t) = T(ax) + T(by) = aTx + bTy,
So, T(ax + by) = aTx + bTy ?
Any closer?
Any closer?
Way closer. In fact, you finished it. Just say at what point you used (2.1.3).
So letting s=ax and t=by was the right thing to do?
Are there other ways to say 2.1.1 stems from 2.1.2 and 2.1.3?
You just did it. T(s+t)=T(s)+T(t)=T(ax)+T(by) by (2.1.2). Now (2.1.3) says T(ax)=aT(x) and T(by)=b*T(y). Doesn't that mean you are done??
