Prove the equation using Newton's binom
  • Thread starter Thread starter Lilia
17 replies · 2K views
Lilia
prove that sum C(2n,k)*k = n*2^(2n-1); k=0,n
(x+y)^n = sum [C(n,k)*x^k*y^(n-k)]; k=0,n. // 1
in // 1, when y=1: (1+x)^n = sum [C(n,k)*x^k]; k=0,n // 2
in // 2, when x=1: 2^n = sum [C(n,k)]; k=0,n // 3
derivatives of both sides of (1+x)^n = sum [C(n,k)*x^k]; k=0,n:
n(1+x)^(n-1) = sum [k * C(n,k) * x^(k-1)]; k=0,n // 4
in // 4, when x=1: n*2^(n-1) = sum [k * C(n,k)]; k=0,n // 5
from // 5, i'll have
sum [C(2n,k)] = 2^(2n); k=0,2n
then i tried to divide this by 2:
sum [C(2n,k)] = 2^(2n)/2 = 2^(2n-1); k=0,n
but then i realized this can't be correct because there are
n+1 numbers in the range 0-n,
2n+1 numbers in the range 0-2n
so i can't really divide 2n+1 by two and get n+1
Hint: C(2n,n+k) = C(2n,n-k) and (n+k) = 2n - (n-k), so you can relate sum_{k=n..2n} k C(2n,k) = sum_{k=1..n} (n+k)C(2n,n+k) to sum_{k=1..n} k C(2n,k).
sum_{k=0..2n} k C(2n,k) = n*2^(2n)
if it was sum_{k=1..2n} k C(2n,k) = n*2^(2n), i'd just divide both sides by 2 and prove the equation
yes...
but i don't understand why these are equal:
is this correct?
sum {k=1,2n} c(2n,k) * x^k = (1+x)^(2n)
sum {k=1,2n} k * c(2n,k) * x^(k-1) = 2n * (1+x)^(2n-1)
sum {k=1,2n} c(2n,k) = 2^(2n-1), when x=1
n * 2^(2n-1) = [sum {k=1,2n} c(2n,k)] / 2 = sum {k=1,n} c(2n,k)
^^only the second is correct though the sum should start at 0 to fit the others
in all k should start at 0
in the third and forth even though you had k * c(2n,k) in the second the k disappeared
sum {k=0,2n} c(2n,k) * x^k = (1+x)^(2n)
sum {k=0,2n} k * c(2n,k) * x^(k-1) = 2n * (1+x)^(2n-1)
sum {k=0,2n} k*c(2n,k) = 2^(2n-1), when x=1
n * 2^(2n-1) = [sum {k=0,2n} k*c(2n,k)] / 2 = sum {k=0,n} k*c(2n,k)
oh yes, that's true
but i don't get how these two are equal - [sum {k=0,2n} k*c(2n,k)] / 2 = sum {k=0,n} k*c(2n,k)
for the left part we have
c(2n,0)*0 + c(2n,1)*1 + ... + c(2n,n-1)*(n-1) + c(2n,n)*n + c(2n,n+1)*(n+1) + ... + c(2n,2n)*2n
having c(2n,k) = c(2n,2n-k), by summing all the coefficients of these c(2n,k) = c(2n,2n-k) i'll have that every term's coefficient is 2n, except for c(2n,n)*n.
after this, i don't think i can divide sum {k=0,2n} k*c(2n,k) by 2 and say it's equal to sum {k=0,n} k*c(2n,k)
Lilia said:
oh yes, that's true
For ##n=6## the sequence of values ##k \,C(12,k)## for ##k=1 \ldots 12## is
12, 132, 660, 1980, 3960, 5544, 5544, 3960, 1980, 660, 132, 12 .
We do, indeed, have ##\sum_{k=1}^6 k\, C(12,k) = \sum_{k=7}^{12} k \,C(12,k)= (1/2)\sum_{k=1}^{12} k\, C(12,k)##.
However, you need to prove that in general, for any ##n##.
but why are there two 5544's? we have only one c(12,6). for others there are equals, for example c(12,8) = c(12,4) etc.
Do the calculation yourself: (1) compute C(12,k) for k = 1, 2, ..., 12; (2) multiply the entries by k = 1,2,..., 12, to get the sequence k*C(12,k) for k from 1 to 12.
It seems odd that the C's go up and then down again as k increases, while the entries k themselves continue to go up, but nevertheless their product goes up, then down and in a symmetric way. Until you have seen it happen you might not believe it; that is why a numerical example is helpful.
okay, i need to prove that sum {k=0,n} k*c(2n,k) = 1/2 * sum {k=0,2n} k*c(n/k)
for n=3,
for on left side i have ##\text{0*c(6,0) + 1*c(6,1) + 2*c(6,2) + 3*c(6,3) = 0 + 6 + 15 + 60 = 81}##
and on the right side ##\text{0*c(6,0) + 1*c(6,1) + 2*c(6,2) + 3*c(6,3) + 4*c(6,4) + 5*c(6,5) + 6*c(6,6)] = 81 + 60 + 30 + 6 = 177}##
since ##\text{c(n,k) = c(n,n-k)}##, here we can notice that the sum of the coefficients of c(2n,k) and c(2n,2n-k) is 2n but this isn't true for c(2n,n)
for example, ##\text{c(6,1) = c(6,5)}##, the sum of their coefficients: 1 + 5 = 6 = 2n, the same holds for the others but c(6,3) is unique
and also ##\frac {177} 2 ≠ 81##
for n=3,
Of course, ##\sum_{k=0}^n k C(2n,k) = \sum_{k=1}^n k C(2n,k)##, etc., and that is why I wrote the sums starting from 1 instead of 0. You get the required symmetry when you start at 1.
Beyond that, I don't know what else I can say without solving the problem for you. You need to actually evaluate numerically the terms ##k C(12,k)## to see what you get. But, I would suggest you do another case instead, so maybe look at ##n = 5## and thus look at the sequence ##k C(10,k)## for ##k = 1,2, \ldots, 10##. Do not leave the terms in symbolic form such as ##7 C(10,7)## for example; evaluate them numerically, so that you write ##840## instead of ##7 C(10,7).##
i calculated the second term wrong, so for n=3 the sequence of terms is
##\text{0 6 30 60 60 30 6}##
so it turns out that ##\text{n*c(2n,n) = (n+1)*c(2n,n+1)}## and i really wonder why and how
##\text{(n+1)*c(2n,n+1) = n*c(2n,n+1) + c(2n,n+1)}## but this doesn't get me anywhere
