Prove the expressions by induction method
The discussion centers around solving several mathematical proofs and problems using induction and algebra. The first problem involves proving a summation formula, but the user struggles with the initial steps and understanding the expression. The second question requires proving an inequality by induction, where the user has made some progress but is unsure about the next steps. The third question focuses on proving the derivative of x^n using induction, with hints provided about applying the product rule. Lastly, the fourth question involves solving a quadratic equation and determining conditions for its real roots, with some guidance given on how to approach the problem. Assistance is requested for all questions due soon.
salubadsha
hey guys
1st week of my university and i got the painful assignment. I've not touched math from last 4-5 months, so I'm having trouble with few questions. Please help me out, thanks in advance
1- Prove that if x not equal 0, then x + 2x^{2} + 3x^{3} + ... + nx^{n}(1+x) = [ x - (n - 1)x^{n+1} + nx^{n+2} ] / (1-x)^{2} for every poitive integer n.
2-Prove by induction that if x \geq 0 (1+x) ^n \geq 1+nx
3- Using the fact that d/dx(x) = 1 and the product rule, prove by induction that d/dx(x^{n}) = nx^{n-1} for every poitive integer n.
4- (a) Treating the equation 4x^2 +4xy +2y^2 − 4x − 2y +1 = 0 as a quadratic equation in x with coefficients in terms of y, solve for x.
b) Disprove the statement “For all real numbers x and y, 4x^2 +4xy +2y^2 − 4x − 2y +1 = 0”.
1st question: i tried n = 1 & then n = k but it didn't work out
2nd question: here's what i've
n = 0 (1 + x)^0 ≥ 1 + 0x. And that's true!
assume the expression is true when n = k
(1 + x)^k ≥ 1 + kx.
Prove for n = k + 1
(1 + x)^k + 1 ≥ 1 + (k + 1)x.
So (1 + x)^k + 1 = (1 + x)^k (1 + x)
From the 1st hypothesis
Therefore, (1 + x)^k (1 + x) ≥ (1 + kx) (1 + x)
after this I've no idea how to solve the rest of it
3rd question: no clue at all how to get started
4th question part a: since we need to put the who expression into ax^2 + bx + c so this is what i did
4x^2 + 4(y-1)x + 2y^2 - 2y + 1 = 0
therefore a = 4, b = 4(y-1) and c = 2y^2 - 2y + 1. I tried to use the quadratic formula but it doesn't give me a real root. Maybe i did something wrong and for part b i don't know how to solve it.
Please guys help me out as soon as possible, these question are due withing few days. All the help would be really apperciated , again tons of thanks in advance!
I don't understand what
is supposed to mean. In particular, what is the left side if n= 1? Do you really have that (1+x) term at the end?
(1 + x)^k ≥ 1 + kx.
Prove for n = k + 1
What is (1+ kx)(1+ x)? Multiply it. (And be careful about parentheses. (1+ x)^k+ 1 is not the same as
(1+ x)^(k+1)!)
3- Using the fact that d(x)/dx= 1 and the product rule, prove by induction that d(xn)/dx= n xn-1 for every poitive integer n.
It says "by induction" doesn't it? When n= 1, what is d(xn)/dx= n xn-1? If you know d(xk)/dx= k xk-1 for some k, what is d(xk+1)dx? (Hint: the problem says use the product rule: xk+1= x(xk).
nope sorry my bad, the correct statement is this:
x + 2x^{2} + 3x^{3} + ... + nx^{n}= [ x - (n - 1)x^{n+1} + nx^{n+2} ] / (1-x)^{2}
(1+ x)^(k+1)!)
I did mutliply it and this is what i got: 1 + x + kx + kx^2 but then i don't know how to proof that (1+x)^k(1+x) ≥ 1 + (k + 1)x
if i continue from here, i'll get
d(xk+1)/dx = (k + 1)(xk[/sup)
L.S. = d [(xk)(x)]/dx now if sub the d(xk)/dx value which is kxk-1 then
L.S. = kxk-1 . d(x)/dx Is this correct?
If the last statement is correct then could you please tell me how to solve the rest of it? Even if i use the definition of derivative i can't get the L.S. = R.S.
Any hints for question # 4?
Please someone help me with these, thanks!
for question 4 the answer isn't a real root (should be x=(1-y(1+-i))/2
for part b you need to find a value of y such that y(1+-i) is real so y must be 0 and x is 1/2
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
