Prove $x>2y$ Given $e^y=\dfrac{x}{1-e^{-x}}$
  • Context:
  • Thread starter Thread starter anemone
7 replies · 3K views
anemone
MHB
POTW Director
Hi MHB,
Problem:
Assume $x>0$, and $y$ satisfy that $e^y=\dfrac{x}{1-e^{-x}}$, prove that $x>2y$.
Attempt:
I first tried to express $y$ in terms of $x$ and get:
$y=x+\ln x- \ln (e^x-1)$
and I am aware that one of the method to prove the intended result is to rewrite the equation above as
$y-\dfrac{x}{2}=\dfrac{x}{2}+\ln x- \ln (e^x-1)$
and if I can prove $\dfrac{x}{2}+\ln x- \ln (e^x-1)<0$, which also implies $y-\dfrac{x}{2}<0$, then the result is proved.
Now, I see it that no inequality theorems that I know of could be applied to the expression $\dfrac{x}{2}+\ln x- \ln (e^x-1)$ and hence I get stuck, so stuck that I wish to drop this problem behind my mind!
But, I hope to solve it nonetheless and that's why I posted it here and hope someone can chime into help me out.
Thanks in advance.
Re: Prove x>2y
Can you show that the given definition of $y$ and the inequality implies:
$$\sinh\left(\frac{x}{2} \right)>\frac{x}{2}$$ ?
After that, a bit of calculus is all you need to demonstrate this is true. :D
Re: Prove x>2y
We can simplify the terms of natural logarithm in $\dfrac{x}{2}+\ln x- \ln (e^x-1)$ and get:
$\dfrac{x}{2}+\ln x- \ln (e^x-1)=\dfrac{x}{2}+\ln \dfrac{x}{e^x-1}$
and to be honest with you, I don't understand how to get what you obtained.
Re: Prove x>2y
I began with the given inequality:
$$x>2y$$
and this implies:
$$e^x>e^{2y}=\left(e^y \right)^2=\left(\frac{x}{1-e^{-x}} \right)^2=\left(\frac{xe^x}{e^x-1} \right)^2$$
Hence:
$$e^x>\frac{x^2e^{2x}}{\left(e^x-1 \right)^2}$$
Multiplying through by $$\frac{\left(e^x-1 \right)^2}{e^{2x}}>0$$ we obtain:
$$e^{-x}\left(e^x-1 \right)^2>x^2$$
Now this implies:
$$e^{-\frac{x}{2}}\left(e^x-1 \right)>x$$
$$e^{\frac{x}{2}}-e^{-\frac{x}{2}}>x$$
Dividing through by 2:
$$\frac{e^{\frac{x}{2}}-e^{-\frac{x}{2}}}{2}>\frac{x}{2}$$
Using the definition of the hyperbolic sine function, we may now write:
Re: Prove x>2y
Ah, I see...thanks!
Re: Prove x>2y
anemone said:
Hi MHB,
Problem:
Attempt:
Thanks in advance.
I'm afraid that You have to try the McLaurin expansion around x = 0 of the logarhitm of the function... $\displaystyle y = \ln x - \ln (1 - e^{-x})\ (1)$Starting from f(0) and using l'Hopital rule You have... $\displaystyle \lim_{x \rightarrow 0} \frac{x}{1 - e^{-x}} = \lim_{x \rightarrow 0} e^{x} = 1 \implies y(0) = 0\ (2)$
The procedure for the derivatives however is much more complex and 'Monster Wolfram' can supply a significative aid...
ln x - ln [1 - e^(- x)] - Wolfram|Alpha
The McLaurin expansion we are interersted for is...
$\displaystyle y(x) = \frac{x}{2} - \frac{x^{2}}{24} + \frac{x^{4}}{2880} + \mathcal {O} (x^{6})\ (3)$
As curiosity y(x) is defined for all value of x [positive as well as negatives...] and is $y(x) \le \frac{x}{2}$. May be that a simpler approach to the problem exists and, if yes, it must be found... Kind regards $\chi$ $\sigma$
Re: Prove x>2y
Hey chisigma, thank you for your reply...and I am happy to learn these two methods to solve the problem!
I think MarkFL's approach is very straightforward and smart! :):o
Re: Prove x>2y
Here's another solution which just uses a careful application of the mean value theorem.
