Proving A=B ∪ (A ∩ B) with Distributive Law
  • Thread starter Thread starter senobim
    Law
7 replies · 4K views
senobim
<Moderator's note: Moved from a technical forum and thus no template.>
Greetings! I've been working on basic algebra of sets.
Refer to Exercise 2.4. Use the identities A = A ∩ S and S = B ∪ B and a distributive law to prove that If B ⊂ A then A = B ∪ (A ∩ B). Exercise 2.4 asked to draw Venn's diagram of this case. So I did. (posted from solution manual)
I had really hard time to prove that identity so I've checked solution manual for this part and found this:
B ∪( A ∩ B ) = (B ∩ A) ∪ (B ∩ B ) = (B ∩ A) = A
The only case where this solution could work is when A = B (the only case that I could think of) Or am I missing something? Is there any way to prove it without A = B assumption? (I think, I could prove it using associative law, but clearly exercise only permits distributive. I am confused.)
How are these identities? A ∩ S = A only if A ⊂ S. What is S? How is S equal to B ∪ B? And B ∪ B is just B.
This doesn't make sense to me. If B ⊂ A, then A ∩ B = B, so B ∪ (A ∩ B) = B ∪ B = B, not A.
Yes, the problem confuses me as well.
What book is this from? Are you sure you have written the problem exactly as stated in the book?
Ohh, after copying the problem, somehow, I've lost complement sets. Excuse me!
The book is Mathematical statistics with application by D.Wackerly et al.
A = A ∩ S , S = B ∪ B'
If B ⊂ A then A = B ∪ (A ∩ B')
Ok, If A = A ∪ B and A = A ∩ B it's possible to prove that identity, although I am still a little confused how is A = A ∩ B if B ⊂ A
By definition the intersection A ∩ B of two sets A and B is the set that contains all elements of A that also belong to B, so that implies A ∩ B = B if B ⊂ A.
Is S the universal set? You don't mention this anywhere, and it's not labelled as such in the image you attached. Many textbooks use U for the universal set, at least those written in English.
If B ⊂ A, then it's not true that A = A ∩ B. It is true that B = A ∩ B in this case.
Edit: I mislabeled the properties I meant, but it's now fixed.
This implication, If B ⊂ A then A = B ∪ (A ∩ B'), is easy to prove using DeMorgan's Laws the Distributive Laws, which is what they have used in the solution you posted (with corrections for complements).
The two forms of this law are:
  • A ∪ (B ∩ C) = (A ∪ B) ∩ (A ∪ C) and
  • A ∩ (B ∪ C) = (A ∩ B) ∪ (A ∩ C)
You wrote this in post #1:
I haven't really looked at this. You said you had omitted the complement marks, so possibly they are missing in this, as well.
S - is a universal set.
In that case answer posted in a solution manual of this book, doesn't make any sense at all (compliment marks added)
B ∪( A ∩ B' ) = (B ∩ A) ∪ ( B ∩ B' ) = (B ∩ A) = A
I fail to see how they are using these law to prove that implication.
My attemp to prove it:
B ∪ (A ∩ B') = [distributive law] = (B ∪ A) ∩ (B ∪ B') = (B' ∩ A) = A
You wrote something similar in post #1. The first equality is wrong. Either the work posted in your book (or wherever) has a typo, or you mistyped what was there.
It should be
B ∪ (A ∩ B' ) = (B ∪ A) ∩ ( B ∪ B' )
Earlier I referred to this as one of De Morgan's Laws, which is incorrect. This is one of the distributive laws of set theory.
Continuing from the above, since B ⊂ A, then B ∪ A = A, and B ∪ B' = S.
So B ∪ (A ∩ B' ) = (B ∪ A) ∩ ( B ∪ B' ) = A ∩ S = ?
The work shown in the solution uses a distributive law of set theory, not De Morgan's Law as I called it.
= A
Solution manual is wrong, I posted exactly as it is. Thank you for your time!
