Proving (A → B) → (∃x)(A → B) in predicate logic
10 replies · 6K views
Mr.Cauliflower
Hello,
I don't know how to prove this:
[tex] \vdash (A \rightarrow B) \rightarrow (\exists x)(A \rightarrow B)[/tex]
First I thought it is just an instantiation of the dual form of the axiom of specification, which says
[tex] \vdash A_{x}[t] \rightarrow (\exists x) A[/tex]
but it probably shouldn't be so easy...
Would someone give me any hints?
Thank you.
Your notation and terminology is different from mine, but yes, it is that easy.
Thank you. Could you tell me the name you use for the axiom I used here? I often don't know how to translate these things from Czech to English when I want to find something on Google.
Different books call it different things. The book I used called it "existential introduction", and in fact it was given in my book as a rule of inference (from [itex]A_x[t][/itex] you may infer [itex](\exists x)(A)[/itex]).
So I suppose there's no problem having unbound x in [itex]A -> B[/itex]?
It would be strange if it was problem, but to be sure...
Well, what exactly does your book say? You have the scheme [itex]\vdash A_x[t] \rightarrow (\exists x)A[/tex], but like I said, your notation is different from mine. How <i>exactly</i> is A<sub>x</sub>[t] defined? I assume it means that every free occurrence of x in A is replaced with t? Does it require that there actually is a free occurrence of x in A? For example, if A is y=y, then can A<sub>x</sub>[t] be defined, and is it just y=y?<br /> <br /> If there are free x in [itex]A \rightarrow B[/itex], then you cannot use the axioms you're given, since if A<sub>x</sub>[t] is defined such that EVERY free occurrence of x is replaced by t, then if A -> B has free occurences of x in it, it doesn't fit the right format to be used in the "axioms of specificatino" scheme. So if there are free x in [itex]A \rightarrow B[/itex], then I would use the following facts:<br /> <br /> [itex]\phi \vdash (\forall x)(\phi )[/itex] for any formula [itex]\phi[/itex]<br /> <br /> [itex](\forall x)(\phi ) \vdash \phi _x[t][/itex] for any term t, and any formula [itex]\phi[/itex].<br /> <br /> [itex]\vdash (\phi _x[t] \rightarrow (\exists x)(\phi ))[/itex], the axioms you've given.[/itex]
We say that term [itex]t[/itex] is substituable for variable [itex]x[/itex] in formula [itex]A[/itex] if for each variable [itex]y[/itex] from [itex]t[/itex] no subformula of [itex]A[/itex] of form [itex](\forall x) B[/itex], [itex](\exists x) B[/itex] contains free occurrence of [itex]x[/itex].
And if this condition is satisfied, then
[tex] A_{x}[t][/tex]
means formula [itex]A[/itex] with ALL occurrences of [itex]x[/itex] substituted with [itex]t[/itex].
AKG said:
Does it require that there actually is a free occurrence of x in A? For example, if A is y=y, then can Ax[t] be defined, and is it just y=y?
Given the definition above, I would say, NO, it doesn't require any occurrence of the variable being substitued and YES, the result of what you wrote is just [itex]y = y[/itex].
AKG said:
If there are free x in [itex]A \rightarrow B[/itex], then you cannot use the axioms you're given, since if Ax[t] is defined such that EVERY free occurrence of x is replaced by t, then if A -> B has free occurences of x in it, it doesn't fit the right format to be used in the "axioms of specificatino" scheme.
I don't get this...if I have let's say formula A
[tex] (x.x = z.x) \rightarrow (z > 0)[/tex]
then if I write [itex]A_{x}[t][/itex], where [itex]t = \sin z[/itex], it is
[tex] (\sin z. \sin z = z.\sin z) \rightarrow (z > 0)[/tex]
and I think it's perfectly ok even though [itex]x[/itex] is of free occurrence in [itex]A[/itex].
Something is wrong here. You mean that subformulas of the form [itex](\forall y)B[/itex] and [itex](\exists y)B[/itex] contain no free occurrence of x.
I don't get this...
I was thinking, for some reason, that t had to be a constant symbol. Since t can be any term, Ax[x] is the same as A, and so the "axiom of specification" does apply.
I think we're both saying the same, I wrote ...no subformula of form....
So the result is that I should know something more about the variables in [tex]A \rightarrow B[/itex] to know if I can directly use the axiom of specification ( = if term [itex]t[/itex] can be substituted for [itex]x[/itex])?<br /> <br /> Or that I can prove it that way?[/tex]
... of the form [itex](\forall \mathbf{x})[/itex]..." but it should be [itex](\forall \mathbf{y})[/itex].
[tex]No, I mean you can use the axiom of specification. I assume that the scheme:<br /> <br /> [tex]\vdash A_x[t] \rightarrow (\exists x) A[/tex]<br /> <br /> holds for any formula A, and any term t. Then, in particular its true that:<br /> <br /> [tex]\vdash (A \rightarrow B)_x[x] \rightarrow (\exists x)(A \rightarrow B)[/tex]<br /> <br /> But [itex](A \rightarrow B)_x[x][/itex] is just [itex](A \rightarrow B)[/itex] so indeed<br /> <br /> [tex]\vdash (A \rightarrow B) \rightarrow (\exists x)(A \rightarrow B)[/tex][/tex]
You're right, it's my typo.
Thank you for help.
