Proving a polynomial has no integer solution
35 replies · 7K views · last reply
timetraveller123
let p(x) be a polynomial with integer coefficients satisfying p(0) = p(1) = 1999
show that p has no integer zeros
p(x) = \sum_{i= 0}^{n}{a_i x^i}
##[/B]
using the given information
a0 = 1999( a prime number)
and
a_n + a_{n-1} ... a_1 = 0
then rewriting p(x)
p(x) = a_n(x_n + \frac{a_{n-1}}{a_n} x^{n-1} ... \frac{1999}{a_n})\\
p(x) = a_n(x-r_1)(x - r_2) ...(x - r_n)\\
i am hoping to do the rest of the proving by contradiction
if i assume the polynomial has integer solution then how can i disprove it
Use Rational roots theorem.
If ##p/q## is a root of the given polynomial then ##p## must be a factor of ##a_0##.
Which means ## p = 1## or ##p = 1999##.
ya i tried doing that what do i get from that
You know that ##q## is a factor of ##a_n##. If ##p/q## is a integer then what condition do you get on ##q## for ##p = 1## ?
P(x) = (qx - p)(Q(x))\\
q|a_n \\
p|1999\\
p = \pm 1 or \pm 1999\\
if p = ±1 then q must also equal ±1
if p = ±1999 then q must equal ±1 or ±1999
q|a_n \\
p|1999\\
So what the possible integer values ?
you mean the roots the possible integer roots are ±1 and ±1999
vishnu 73 said:
you mean the roots
Sorry. Yes I mean roots.
##1## is out because ##p(1) = 1999##. Can you eliminate others ?
i am sorry i just can't think of ways to eliminate the rest give me another hint
edit:
after much trying managed to eliminate just 1 of the roots
if we a
a_n + a_{n- 1} ... a_1 = 0\\
a_n + a_{n-1} ... a_2 = -a_1\\
p(-1) = a_n(-1)^n + a_{n-1} (-1)^n-1 ... -a_1 + 1999\\
p(-1) = a_n(-1)^n + a_{n-1} (-1)^n-1 ... a_2 +a_2 +a_3 + ... a_n + 1999\\
the right hand side will cancel out all the terms with odd subscripts leaving only 2 of each even subscript terms and since they are integers the right hand side is 1 mod 2 thus cannot be zero is this correct?
please give me hints for the next two roots
edit:
if we a
Yes except I think it should be ##p(-1) = a_n(-1)^n + a_{n-1} (-1)^\color{green}{n-1} ... a_2 +a_2 +a_3 + ... a_n + 1999##.
Hint :
Product of roots is ##|a_0/a_n|##
Or ##\dfrac{|a_0|}{|a_n|} = |r_1r_2 \cdots r_n|##
If one root is ##1999##
then,
##|1999| = |a_n||r_2 \cdots r_n| \times 1999 \implies 1 = |a_n||r_2 \cdots r_n|##
If 1999 is a root, how many times might 1999 divide ai1999i? Given that it divides a0 exactly once, what does that tell you about a1? Then, what about the relationship between a2 and a3?
@haruspex
haruspex said:
Did you mean ...−a1+a2−a3+...an+1999...−a1+a2−a3+...an+1999... - a_1 +a_2 -a_3 + ... a_n + 1999?
i think what @Buffu wrote is correct as he substituted ## - a_1 = a_2 + a_3 ... a_n##
@Buffu
following on what you said
## 1 = (\mid a_n \mid)(\mid r_2 r_3 ...r_n) ## since ##a_n ## is integer## \mid a_n \mid = 1 ##
then this make ## p(x) ## a monic polynomial then its roots can only be integers or irrationals not fractions then from ##\mid r_2 r_3 ...r_n\mid = 1## we get that ##r_i## has to equal 1 but its shown that 1 is not possible hence 1999 is not possible is this valid ?
Ok, I misinterpreted the ...
vishnu 73 said:
##1 = (\mid a_n \mid)(\mid r_2 r_3 ...r_n\mid)## since ##a_n## is integer ## \mid a_n \mid = 1##
I'm not following. If ##\mid r_2 r_3 ...r_n\mid=\frac 12 ## then ##(\mid a_n \mid)=2##, etc. How are you ruling that out?
haruspex said:
I'm not following. If ∣r2r3...rn∣=12∣r2r3...rn∣=12\mid r_2 r_3 ...r_n\mid=\frac 12 then (∣an∣)=2(∣an∣)=2(\mid a_n \mid)=2, etc. How are you ruling that out?
oh you i got over excited and did that and i am stuck again one more hint please is there some kind of restriction on an
should i be writing ## \mid a_n \mid ## as ## \mid a_1 + a_2 ... a_{n-1} \mid ## does that help
Did you think about my post #13?
oh i completely didn't see the post only noticed it after you pointed it out don't know what happened there will take a look now thanks oh wait you edited i forgot to see the edit
@ haruspex
are you hinting at geometric series
because i thought of it at first but the fact that a2 + ...an = 0
then i considered all the terms in that to be same but alternating signs but that forces n to be odd this was initial line of thought
i am sorry if am not seeing what you are suggesting
vishnu 73 said:
@ haruspex
If you plug x=1999 into the polynomial you will get a factor of 1999 in every term of the sum. Some terms will have extra factors of 1999. But in the end, the sum is zero if 1999 is a root. Can there be one term with fewer factors of 1999 than the rest? What does that tell you about a1?
oh wow that is smart
0 = a_n 1999^n + a_{n-1}1999^{n-1} ... + a_1 1999 + 1999\\
0= a_n 1999^{n-1} + a_{n-1}1999^{n-2} ... + a_1 + 1\\
a_1 = -1999k -1 \\
0 = a_n 1999^n + a_{n-1}1999^{n-1} ... + (-1999k -1 ) 1999 + 1999\\
0 = a_n 1999^n + a_{n-1}1999^{n-1} ... + (a_2 - k)1999^2\\
k-a_2 = 1999l\\
0 = a_n 1999^n + a_{n-1}1999^{n-1} ... +a_3 1999^3 + (-1999l)1999^2\\
l- a_3 = 1999m\\
a_1 + a_2 + a_3 ...a_n = -1 -1998k -1998l -1998m ... -1998y - 1999z = 0\\
1998(k + l + m ... + y) + 1999 z = -1\\
taking mod 1999
-1(k + l + m ... + y) + 0 ≡ -1
how to proceed?
would i be done if i can show k + l + m ... y ≠ 1
a_1 = -1999k -1 \\
k-a_2 = 1999l\\
l- a_3 = 1999m\\
taking mod 1999
how to proceed?
If you want to think about an alternative approach, can you show that if ##n## and ##m## are integers, that ##n-m## divides ##p(n)-p(m)##?
what information will i get from showing that
i am getting back to where i started
this is what i did someone tell me if this is correct
##\frac{p(l) - p(m)}{l-m}##
for integers l and m
\frac {\sum{a_i l^i} - \sum{a_i m^i}} {l-m} \\
\sum_{i = 2}^{n}{a_i (\sum_{j=0}^{n-1}{l^i m^{n-1-i}})} + 1999
hence showing that ## \frac{p(l) - p(m)}{l-m} = k## for some integer k
assuming it has integer root z and p(z) = 0
then
\frac {p(0) - p(z)} {0 - z} = k\\
\frac{1999}{-z} = k
once again back to proving it is not 1999
then
\frac{1999}{-z} = k
z = \pm 1 && \pm 1999
Sort of, I think. I don't know what the 1999 is doing in there. But it's pretty well known that ##l-m## divides ##l^i-m^i## for all ##i##.
no i know that too but now what do i do with the fact that p(m ) - p(n) is divisible by m - n
Well, think about it. You know ##p(0)##, ##p(1)## and you assume that you have an integer root. Put them all together.
oh i did this help me check if this correct?
assuming z is a root
\frac {p(1) - p(z)}{1 - z} = k_1\\
\frac{p(0) - p(z)}{-z} =k_2\\
\frac{199}{1-z} = k_1\\
\frac{1999}{-z} = k_2\\
this above is not possible as no factors of 1999 are separated by one
Sure. ##z## and ##z-1## must divide 1999. That's impossible.
wow that was easy thanks a lot
is this is a standard trick in solving such problems
but can you help me with proving 1999 is not a root of the polynomial
