Proving |det(1+A)|^2 >=1 by Diagonalizing iA: Linear Algebra Question
4 replies · 2K views
N00813
A is an anti-Hermitian matrix.
Show, by diagonalising iA, that:
|det(1+A)|^2 >=1
A^H denotes hermitian conjugate of A; A^H = -A\
x = Ox' transforms vector components between 2 basis sets.
I know that iA is a Hermitian matrix, so it is diagonalisable.
But I'm not sure what the point of diagonalising iA is.
D = O^(-1)(iA)O
for diagonal matrix of eigenvalues D.
det(iA) = det(D).
I'm floundering around. Any help is appreciated.
|det(1+A)|^2 >=1
D = O^(-1)(iA)O
Therefore [itex]A = O(-iD)O^{-1}[/itex].
Also the eigenvalues of [itex]iA[/itex] (and hence the entries of [itex]D[/itex]) are real.
Hint:
[tex]O^{-1}(I + A)^2O = O^{-1}(I + 2A + A^2)O \\<br /> = O^{-1}(I + 2A + AOO^{-1}A)O[/tex]
and
[tex] \det(O^{-1}(I + A)^2O) = \det ((I + A)^2)[/tex]
Hint:
and
I suppose the first equality equals:
[tex]O^{-1}(I + 2A + AOO^{-1}A)O = (I - 2iD - D^2)[/tex]
(This is the bit I'm a bit wonky on, particularly the 3rd equality. Is that part correct?)
Then [tex]|\det((I + A)^2)| = |\det(I - 2iD - D^2)| = |\det((I-iD)^2)|=|\det(I^2 + D^2)| >= det(I^2) = 1[/tex]
where
Then [tex]|\det((I + A)^2)| = |\det(I - 2iD - D^2)| = |\det((I-iD)^2)|=|\det(I^2 + D^2)| \geq 1[/tex]
If you're not sure that the third equality holds (and it holds only if the eigenvalues of D are real), you should prove it. This will require calculating the quantity you are asked to show is at least 1, at which point you have answered the question.
I suppose, if the action of the complex conjugate is to change the sign of the i:
[tex]|\det((I-iD)^2)| = \det((I-iD) (\det(I-iD))^* = \det(I-iD)\det(I+iD)[/tex]
I suppose I can prove [tex](\det(I-iD))^* = \det(I+iD)[/tex] using suffix notation definition for the determinant.
Thanks!
