Proving Det(B) = k*Det(A): A Fundamental Property of Determinants?
  • Thread starter Thread starter asap9993
    Determinant Proof
The discussion centers on proving that if matrix B results from multiplying a single row or column of matrix A by a scalar k, then det(B) = k * det(A). Participants emphasize the importance of understanding the properties of determinants, particularly that the determinant is a linear application in the rows and that it remains invariant under transposition. The proof hinges on the ability to expand the determinant along any row or column, which is established as a fundamental property of determinants in linear algebra courses. This foundational knowledge allows for the application of the determinant properties without needing to prove them each time.
  • Understanding of linear algebra concepts, specifically determinants.
  • Familiarity with cofactor expansion for calculating determinants.
  • Knowledge of elementary row operations and their effects on determinants.
  • Experience with matrix transposition and its properties.
  • Study the properties of determinants, focusing on linearity and the effects of row operations.
  • Learn about cofactor expansion and its application across different rows and columns.
  • Explore the relationship between determinants and matrix transposition.
  • Review proofs of fundamental properties of determinants in linear algebra textbooks.
Students of linear algebra, mathematicians, and educators seeking to deepen their understanding of determinants and their properties in matrix theory.
asap9993
I need help in proving that if B is the matrix that results when a single row or column of A is multiplied by a scalar k then det(B) = k*det(A).
The only way I could think of is setting up a general n x n matrix where all the entries on one of the rows or columns is multiplied by k. Then I could say that if one uses cofactor expansion along that particular row or column then the k factors out from all the cofactors.
However, the weakness to this method is that I would have to show that it also holds if one decides to expand along a row or column besides the one multiplied by k. I'm not sure if I could do that for every nth row or column.
Don't you already know that it doesn't matter which row or column you expand on, or has that not been proved in your course yet?
Of course everyone knows that. But how do you prove it for EVERY SINGLE POSSIBLE nth row or column for EVERY SINGLE POSSIBLE SQUARE MATRIX? Neither my teacher or my textbook proves it.
I can't just write "Take my word that it doesn't matter which row or column you expand upon" or "the textbook says so" on my proof.
If you could give some me help or tell me where I could find it, I would greatly appreciate it.
What definition of the determinant are you going off? Have you defined what happens to the determinant when you perform an elementary row operation on it?
I'll disagree a bit. If it's in your textbook and you've already covered it, it's fair game to use in a subsequent proof.
When you take math courses, there are all sorts of facts you're using without proof, like the properties of the real numbers. You're not expected to prove real numbers have all these properties before you use them in a linear algebra proof. So part of succeeding in the course is to figure out what you know and what you don't know, in the sense you can use this knowledge without necessarily proving it first.
When I took linear algebra, it was established pretty early that it didn't matter what row or column you expanded on to calculate the determinant, precisely to avoid the issue you're worried about now. That's what I meant by my question, whether it's already considered known to you.
For what I know, this fact for a row directly derives from the properties of the determinant. It is defined:
a) to be a linear application in the rows,
b) to give 0 if two rows are equal,
c) to give 1 if you calculate det(I_n), with I_n the identity matrix.
In particular the answer comes from a).
Instead for a column, you can think that the determinant of A calculated along the i-th column is the same as the determinant calculated along the i-th row of the transpose of the matrix, ^tA. It is well known (and not so long to show) that det(A)=det(^tA). So the situation is reduced to the one explained before.
12K
