Proving Equivalence of 1-1 Function Statements
  • Thread starter Thread starter Incand
    Proof Range
Incand
Let ##f:S\to T## be a given function. Show the following statements are equivalent:
a) ##f## is 1-1
b) ##f(A\cap B) = f(A) \cap f(B),\; \forall A,B \in S##
c) ##f^{-1}(f(A)) = A,\; \forall A \subseteq S.##
Definition:
##f## is 1-1 of ##A## into ##B## provided that ##f(x_1) \ne f(x_2)## whenever ##x_1 \ne x_2, \; \; \; x_1,x_2 \in A##.
Definitions:
Let ##f## is a mapping ##f:A \to B##:
If ##E \subseteq A## then ##f(E)## is the set of all elements ##f(x)## with ##x \in E##.
If ##E \subseteq B## then ##f^{-1}(E)## denotes the set of all ##x\in A## such that ##f(x) \in E##.
I think I'm able to prove a) ##\Longrightarrow## b) and a) ##\Longrightarrow## c) but I can't complete the rest.
Lets first prove the general statement ##A \subseteq f^{-1}(f(A))## :
Take ##\alpha \in A## then ##f(\alpha) \in f(A)## and hence ##\alpha \in f^{-1}(f(A))##.
We can also prove that ##f(A \cap B) \subseteq f(A) \cap f(B)##:
Take ##\alpha \in f(A \cap B)## that means ##\alpha = f(z)## for some ##z\in A \cap B## and hence ##\alpha \in f(A)\cap f(B)##.
It's left to prove the equivalence between
a) ##f## is 1-1
b) ## f(A) \cap f(B) \subseteq f(A\cap B),\; \forall A,B \in S##
c) ##f^{-1}(f(A)) \subseteq A,\; \forall A \subseteq S.##
Take ##\alpha \in f(A) \cap f(B)## then ##\alpha = f(z_1), \; z_1 \in A## and ##\alpha = f(z_2), \; z_2 \in B##. But since ##f## is 1-1 ##z_1 = z_2## hence ##\alpha \in f(A \cap B)## and ## f(A) \cap f(B) \subseteq f(A\cap B)##.
Take ##\alpha \in f^{-1}(f(A))## that is ##z = f(\alpha)## for some ##z\in B##. That is
##f(\alpha) \in f(A)## hence ##f(\beta) = z## for some ##\beta \in A## but since ##f## is 1-1 this means ##\alpha = \beta## and ##\beta \in A## so ##f^{-1}(f(A)) \subseteq A##.
To complete the proof I need to either show that c) ##\Longrightarrow## a) and b) ##\Longrightarrow## c) OR show that c) ##\Longrightarrow## a) and b) ##\Longrightarrow## a).
It's equivalent to show the contrapositive that ##f(x_1) = f(x_2) \Longrightarrow x_1 = x_2##. Take ##x_1, x_ 2 \in A## so that ##f(x_1)= f(x_2)## then by c) ##x_1,x_2 \in f^{-1}(f(A))##. This means that ##z_1 = f(x_1)## and ##z_2 = f(z_2)## for ##z_1,z_2 \in B## but from the premise ##z_1 = z_2##.
I don't seem to get anywhere with the last part nor any luck with any of the other equivalences. Any hints on how to go about it? I'm also wondering If what I've done so far is correct?
a) ##f## is 1-1
Definition:
Definitions:
a) ##f## is 1-1
a) ⇒ b) and a) ⇒ c) are correct.
I don't exactly understand what you did in c) ⇒ a)
Hint for b) ⇒ c)
Take ##A \subset S##, and set ##B=f^{-1}(f(A)) \setminus A##. Use b) to prove that ##B= \varnothing##.
Hint for c) ⇒ a)
Take ##x\in S## and apply c) to ##A=\{x\}##.
Cheers! The hints really helped! Think I got them now.
Let ##A \subseteq S## and set ##B = f^{-1}(f(A))\backslash A## then ##A \cap B = \varnothing##. Using b)
##f(\varnothing ) = f(A \cap B) = f(A)\cap f(B), \; \; \forall A \subseteq S##. Hence
##f(\varnothing ) =f(B)## but ##f(\varnothing) = \varnothing## and ##f(B) = \varnothing## only when ##B = \varnothing## so ##B=\varnothing##.
This gives us that ##f^{-1}(f(A)) = A, \; \; \forall A\subseteq S##.
Take ##x\in S## and take ##A = \{x\}## then by c) ##f^{-1}(f(A)) = A= \{x\}##. Since the inverse image of ##f(A)## has only one element there is only one ##x## satisfying ##z=f(x)## for each ##x\in S##. That means if ##x_1 \ne x_2## ##f(x_1) \ne f(x_2)## and hence ##f## is 1-1.
