Proving LUB and GLB Properties in Ordered Fields
  • Thread starter Thread starter ragnes
    Properties
An ordered field possesses the Least Upper Bound (LUB) property if and only if it has the Greatest Lower Bound (GLB) property. The proof requires demonstrating that if an ordered field has the GLB property, it necessarily has the LUB property, and vice versa. Key to this proof is the relationship between a set S with a lower bound and the set (-1)*S, which possesses an upper bound. The proof hinges on the properties of ordered fields, particularly the behavior of inequalities under multiplication by -1.
  • Understanding of ordered fields and their properties
  • Familiarity with the concepts of upper and lower bounds
  • Knowledge of mathematical proofs and logical reasoning
  • Basic understanding of inequalities and their manipulation
  • Study the properties of ordered fields in depth
  • Learn about the implications of LUB and GLB in real analysis
  • Explore proofs involving inequalities and their transformations
  • Investigate examples of ordered fields beyond the real numbers
Mathematicians, students of abstract algebra, and anyone interested in the foundational properties of ordered fields and their implications in mathematical analysis.
ragnes
1. Prove that an ordered field has the LUB property iff it has the GLB property.
I know that I need to prove that if the ordered field has the GLB property, then it has the LUB property, and that if the ordered field does NOT has the GLB property, then it also does not have the LUB property. I'm just really stuck on how to start the proof - do you assume the ordered field is bounded?
Any help would be appreciated!
Hint: if a set S has a lower bound, what can you say about the set (-1)*S?
That it has an upper bound?...
Yes. And how is the lower bound of S related to the upper bound of (-1)*S?
Don't guess! If U is the LUB, it is, first, of all, an upper bound. In other words, for any x in the field, x\le U. Multiplying both sides by -1, -x\ge -U. But if y is any member of the field, x= -y is also in the field and so y= -x\ge -U. That is, -U is a lower bound. Now you need to show it is the greatest lower bound.
Don't forget that this is an "ordered field", not necessarily the field of real numbers. What is meant by "-1"? Have you proven or can you prove that "if a< b, then -a> -b"?
