Proving N and Z are closed sets using complements
Math Amateur
MHB
I am reading Houshang H. Sohrab's book: "Basic Real Analysis" (Second Edition).
I am focused on Chapter 2: Sequences and Series of Real Numbers ... ...
I need help with a part of Exercise 2.2.4 Part (3) ... ...
Exercise 2.2.4 Part (3) reads as follows:
Exercise 3 from a textbook: Show that N and Z are closed, whereas the set {1/n : n in N} is neither closed nor open.
The definitions of open and closed sets are relevant as is the definition of an \epsilon neighborhood. Sohrab defines these concepts/entities as follows:
Typeset textbook excerpt giving Definition 2.2.1 (distance and epsilon-neighborhood) and Definition 2.2.2 (open and closed sets), with Example 2.2.3 on the empty set and R, open and closed intervals, and half-open intervals.
Reflecting in general terms, I suspect the proof that ##\mathbb{N}## and ##\mathbb{Z}## are closed is approached by looking at the complements of the sets of ##\mathbb{N}## and ##\mathbb{Z}## ... visually ##\mathbb{R}## \ ##\mathbb{N}## and ##\mathbb{R}## \ ##\mathbb{Z}## and proving that these sets are open ... which intuitively they seem to be ... but I cannot see how to technically write the proof in terms of open sets and ##\epsilon##-neighbourhoods ... can someone please help ...
I have not made any progress regarding the set ##\{ \frac{1}{n} \ : \ n \in \mathbb{N} \}## ...
Peter
  • Printed exercise 3: Show that N and Z are closed, whereas the set {1/n : n in N} is neither closed nor open.
  • Typeset textbook excerpt giving Definition 2.2.1 (distance and epsilon-neighborhood), Definition 2.2.2 (open and closed sets), and Example 2.2.3 stating that the empty set and R are the only sets both open and closed.
Pick any real number, r (use a variable, not a specific number), not in the set and determine ε such that 2ε is the distance to the nearest number in the set. Proceed from there.
Thanks FactChecker ... I am assuming you are referring to the set ##\{ \frac{1}{n} \ : \ n \in \mathbb{N} \}## and not to the proof that ##\mathbb{N}## and ##\mathbb{Z}## are closed ... is that correct ... ?
Peter
Peter
For N and Z, you can use it to prove that the complement is open. For the 1/n set, you can use it to prove that the complement is not open. It is using the definitions of open and closed sets directly, which is what you want to do unless you have some other proven theorems to use.
Hi FactChecker ... I am still perplexed ...
Can you help further ...
Peter
Do you know whether an arbitrary union of open sets is open; that is, if ##\{U_i\}_{i \in I}## is some collection of open intervals, do you know whether ##\bigcup_{i \in I} U_i## is open? It shouldn't be hard to prove it from the definition you provided in your OP. If so, you should be pretty straightforward to write the complement of ##\Bbb{N}## and ##\Bbb{Z}## as the union of open intervals.
As for showing the set ##\{1/n ~|~ n \in \Bbb{N} \}## is neither closed nor open, consider the numbers ##0## and ##1##. Using ##0## will help you show that it isn't closed, whereas ##1## will help you show that it isn't open.
