Proving natural numbers equal {1,2,3,4...} from inductive sets
  • Level: Graduate
  • Thread starter Thread starter mollysmiith
    Curious
1 reply · 5K views · last reply
mollysmiith
Analysis math help please!?
1. Let E be a nonempty subset of R (real numbers)
Prove that infE <= supE
2. Prove that if a > 0 then there exists n element N (natural) such that 1/n < a < n
3. A subset E of te real numbers R is an inductive set if
i) 1 element E
ii) If x element E then x + 1 element E
A real number is called a natural number if it belongs to every inductive set. The set of natural numbers is denoted by N. Recall that the principle of mathematical inductions says that if M is any subset of N that is an inductive set then M = N. Show that N = E, where E = {1,2,3,4...}
Any help would be greatly appreciated ! :)
The infimum of E is defined as a lower bound for E: inf E<= x for any x in E.
The supremum of E is defined as an upper bound for E: x<= sup E for any x in E.
Put those two together. Do you see why the fact that E is non-empty is important?
I don't know what theorems you have to base this on but one fundamental property is the "Archimedean property": given any real number, a, there exist an integer such that a<n. Of course, if a> 1, then 1< n also so that 1/n< 1< a. If 0< a< 1, look instead at 1< 1/a< n. In that case, 1/n< a and, of course, a< 1< n.
i) 1 element E
Show that every inductive set contains, at least, {1, 2, 3, 4, ...}.
Note that the definition "inductive set" above does not restrict its members to the natural numbers. For example, the set {1/2, 1, 3/2, 2, 5/2, 4, 9/2, 5...} is an "inductive set". Another is {2/3, 1, 5/3, 2, 8/3, 3, 11/3, 4, ...}. But you can prove that N is a subset of every inductive set.
