Proving Polynomial Irreducibility over Z
  • Thread starter Thread starter Discover85
    Polynomial
The discussion revolves around proving the irreducibility of the polynomial \( f(x) = (x-1)(x-2)\cdots(x-n) + 1 \) over the integers for \( n \geq 1 \) and \( n \neq 4 \). Participants explore various mathematical properties and conjectures related to this polynomial.
  • Participants discuss the implications of setting \( f(x) = h(x)g(x) \) and the conditions under which \( h(x) \) and \( g(x) \) can be determined. There is mention of Brocard's problem and its relation to the irreducibility proof. Some participants question the validity of the equation \( n! + 1 = j^2 \) and discuss the significance of even versus odd values of \( n \). The use of derivatives to analyze the polynomial's behavior is also considered.
The discussion is active, with participants providing insights and raising questions about the polynomial's properties. Some have suggested potential avenues for further exploration, such as the relationship to Eisenstein's criterion and the implications of the polynomial's minimum value. There is no explicit consensus on the approach or solution yet.
Participants note that the problem is constrained by the requirement to prove irreducibility for specific values of \( n \) and the challenges posed by known results related to perfect squares. The discussion reflects a mix of established mathematical concepts and ongoing inquiries into the problem's nuances.
Discover85
Prove that the polynomial $(x-1)(x-2)...(x-n) + 1$ is irreducible over Z for n\geq 1 and n \neq 4
N/A
Let $f(x) = (x-1)(x-2) \cdots (x-n) + 1$ and suppose $f(x) = h(x)g(x)$ for some $h,g \in \mathbb{Z}[x]$ where $\deg(h), \deg(g) < n$. Note that $f(x) = 1$ for $x \in (1,2,\ldots,n)$ and so $h(x)g(x) = 1$ for $x \in (1,2,\ldots,n)$. This implies that $h(x) = \pm 1$ and $g(x) = \pm 1$ for those $x$ values. Moreover, we must have $g(x) - h(x) = 0$. Since a polynomial of degree $m$ is determined by $m+1$ points we have that $h(x) = g(x)~\forall x$. This implies that $f(x) = g(x)^2$. Now consider $f(n+1) = g(n+1)^2$. We have that $n! + 1 = j^2$ where $j \in \mathbb{Z}$. I feel like I'm close but don't know where to go from here... Any help will be greatly appreciated!
That's really very clever. You've reduced it to Brocard's problem. The trouble is that you've reduced it to a really hard problem. The known solutions are that 4!+1, 5!+1 and 7!+1 are perfect squares. But whether there are more is still, as far as I know, an open question. BTW you don't have to worry about 5 or 7. n!+1=j^2 isn't quite the right equation. You really only have to worry about n even. Maybe that has an easier solution??
Yeah, I realized I had reduced it to something fairly ugly when I was using Wolfram and found 7! + 1 fit the bill. I don't know if this helps but this question was posed under the Eisenstiens Criterion section.
Well, 7!+1 is a perfect square but that's still not an exception to irreducibility since you would need -7!+1 to be a perfect square. And it's not. You've got a sign missing in the n!+1=j^2 criterion. Odd values of n are really no problem. It's the even ones I'm worried about. And I've been scratching my head over this for a while and I don't know what to do with it. A trick you can sometimes pull with the Eisenstein Criterion is that p(x) is irreducible iff p(x+k) is irreducible for every integer k. But I'm not getting that to go anywhere either. Maybe it's just late and I'm thinking the wrong way about it. You try again and we'll compare notes.
From my proof we know that for n<4 the polygon is irreducible since n! + 1 != m^2. As for n>5, you can take the derivative and show that the polygon has a minimum less than 0. This contradicts the fact that f(x) = g(x)^2. Thus n = 4.
Ok, the minimum thing works. That's also really clever! I can see how that works by substituting a value like x=n-1/2. How does using derivatives prove it more easily? Doesn't have much to do with Eisenstein's criterion, does it?
